Question about HP L1720 17 in. Flat Panel LCD Monitor
Exactly the same problem!
After using the monitor for more than 15-20 min it gets flikering lines.
This has nothing with the display's hardware. I thing it's because of the power supply board in the left, but the problem can't be solved only with change of the capasitors.
Has anybody any idea for this problem!
4 Suggested Answers
bhagyavichar
  • 414 Answers
SOURCE: monitor display problem
though itz very unclear n i don't understand the moral meaning of windows going down..!!..n wat is the link of windows going down with ur monitor..
however, itz probably causing from faulty or defective smps or main/mother board..
if not probably itz causing from the monitor itself..
proceed to verify with the below stated steps, only if u r a professional..
DO IT ONLY IF U R A PROFESSIONAL..
..plz do check the following as in order:..
the Hardware part:..
1) check mains/power supply..the fuse, switch, wiring n associated circuitry..
2) [in case of desktop] thesmps itself may b defective/faulty..check the outputs of smps viz. 0v(black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg&grey~sb); -12v (blue);-5v(white); +3.3v(orange)..
check the battery n adapter [main power], in case of laptops..
replace with a standby n see..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) open the cpu n see if heat is generated..if not..replace the cpu n see..
5) open the CPU Heat-Sink with fan out of thesocket..put some "Heat Sink Compound" (available in local electronicschip level spare market)between the cpu/processor and the CPU Heat Sink*** fan..resit/fit it tightly in position..
6) on main/motherboard..see with a debug card for mb error..may b short..look fordefective capacitors(espabove1000mfd)/mosfets..go through the mb'ssouth bridge n the circuit lie around atx connector..the crystal clockgenerator (if cpu isn't heating up)..
7)seeif the ram(s) is loose/faulty..open clean/remove carbon & or oxideformed on the teeth with an eraser n resit it..or replace with a standbyn see..
8)remove/clean dustneatly..dust is non-uniform in nature n may causejam/short circuitry/excess resistance n many more..resulting an increasein heat..
9) if all above fails..just try to service the monitor..open and re-sould all the dry soulderings..itz probably is causing due to ur monitor's internal circuit dry-soulds..esp. at the crt base n around the horizontal output section (hot)..
the Software part:..
1)hv a licensed and UPDATEDantivirus installed (i prefer avg/kaspersky,remember, without updationa full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeall the unnecessary startup items from here..(if u can't find whatto remove, post me/us in ur comment with all the items listed in eachn every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a)'Automatically Restart'right click on my computer->properties->advanced->startupn recovery->(un check on the) Automatically Restart;
b)'Error Reporting'right click onmy computer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when critical erroroccur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 16, 2009
  • 732 Answers
SOURCE: Have HP PE1230 monitor, I am getting 12.5 VDC from
dlquadt698, possible failure of inverter electronic "ballast" circuit??? Try here if you havent already done so. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ might be of some help. 12fixlouie
Posted on May 20, 2010
budmrtn
  • 11361 Answers
SOURCE: hp monitor L1502 is dead,
Look for bad caps as shown in my pictures here first,
http://s807.photobucket.com/albums/yy352/budm/HP%201502/
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 01, 2010
When i turn my computer the screen stays black and flikers for a bit
The problem is in the inverter board located below the LCD screen, or the built in backlight behind the display. I would hook a monitor to the video output to rule out the video graphics chip.
Jun 24, 2012 | Lenovo Computers & Internet
I am geeting lines in the center
I try a different video cable. Sometimes a wire goes bad or pin gets bent.
The more likely cause is simply a bad monitor. If it is still under hardware warranty I would say look into getting a replacement. Depending on how expensive a new one is versus how much a repair costs I would explorer those options. There is nothing that can be done in software though, it is a hardware issue.
Jun 05, 2010 | Apple Cinema HD 30" LCD Monitor
Blue lines on dell lap top inspiron
Check whether blue lines are present in bios screen, if Present then Hardware issue
If Blue line not present in bios screen, Software issue = Restore system back to factory settings
Connect External Monitor, use Fn + F8 to extend display on external Monitor ,
if display is fine on Ext Monitor = Replace LCD Kit
if Blue lines are displayed, on Ext Monitor = Replace Motherboard
Jan 09, 2010 | Dell Computers & Internet
My Westinghouse monitor fliker for 1 sec and dont diaplay anythin
Make sure all cables are tight if that doesn't work you need to put it in the shop if its still under warranty if not you need a new one
Mar 10, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Is there any display driver for synmaster 540n
http://www.samsung.com/it/function/search/resultList.do?searchWord=540n
Mar 05, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Samsung LCD 192N After 30 Min or so it starts flikering on & off.
The capicators on the internal power supply are overheating. You could get it repaired or find a way to cool the unit.
May 12, 2008 | Gateway FPD2275W LCD Monitor
Brown horizontal lines sporadically appearing on monitor
I had the same problem. I fixed it completely today. The horizontal lines disappeared. IT IS DEFINETLY THE DEVICE DRIVER. I confirmed my monitor model tyope (dell M783s) and downloaded the specific driver for this monitor.
I had to do these exact steps or did not work.
1) with the problem screen, disabled the display adapter under the Hardware/Device Manager settings.
2) Restart the PC
3) Boot will come up with brown lines still but the screen will low resolution of 600x800.
4) Then I installed the correct device display monitor driver onto the pc. ( you may need to scan for new hardware, then choose the directory with the new hard drive.)
If you need step by step... just reply back.
Dec 02, 2007 | Dell M781S Monitor
HP L1720 17 in. Flat Panel LCD Monitor Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
