Question about Poulan Garden
Rob poulan leaf blower how to rewind pull string
    President:
  • 2,220 Answers
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled. HTH
Lou
Posted on Sep 06, 2009
Echo gt 200r
This is a blower, right? What string are you talking about?
Apr 17, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Rewind pull cord poulan pro snowblower pulled cord first time and will not rewind back
If you are a fix it kind of guy you can remove the starter assembly and check the recoil spring.
Dec 19, 2013 | Poulan Garden
MY POULAN LEAF BLOWER PULL CHORD DOES NOT REWIND AS THE RESULT I CANNOT START THE BLOWER
This is a fairly common problem. Take a flat head screwdriver, place it through the holes in the starter cover and move the plastic inside gently. This should jar it loose and allow the cord to rewind.
Aug 30, 2011 | Poulan 25CC Gas BlowerVac
Replacing pull string on Poulan BVM200VS leaf blower
You will need to split the housing and remove the impeller wheel. In doing this you will have to disconnect the throttle cable and the switch assy. This can be a hand full if you have never done one.
In the future when you are purchasing a string trimmer or blower
or hedge trimmer, be sure that the starter can be removed by
removing 4 screws. This makes starter repair a 5 minute $10 job
instead of an hour $40 or more job. The problem is that you will
not find this in most home centers or box stores. You will have to
go to a full service dealer.
Sep 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
The pull cord will not rewind
Sounds like the rewind spring has broken or the starting spool is broken or the piston is stuck. You will have to take the machine apart to see what it is that stops it from rewinding. I'm thinking spring.Good luck...Lee
Sep 09, 2009 | Poulan Garden
Pull string broke on crafstman 6.75 mower
when the rope broke you first must rewind sring and load tension on it first then install spring while it is underload clamp with vise grips until string is fed through then release slowly allowing string to recoil
Jul 15, 2009 | Toro Lawn Mower With Toro Power Tools
Starter cord not recoiling
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
May 26, 2009 | Poulan "Poulan" Pp325 17" Gas Brushcutter...
Putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Oct 10, 2008 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
370 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
