Question about E-Machines eMachines Desktop PC
How to use my HDTV for a monitor for my computer
I need a wireless router that I can use to connect my computer with my HDTV. I have an Element HDTV and an E-machines computer.
    Novelist:
    Champion:
  • 210 Answers
What video output connection type do you have on your PC.....DVI, VGA, S-VIDEO, HDMI?
What video inputs connection types do you have on your HDTV.....DVI, VGA, S-VIDEO, HDMI?
The cable you need will be whatever connection you have....ie: DVI----->HDMI or VGA----->VGA or DVI to DVI.
You will also need an audio cable, 2 Phono RCA Red/White (Left and right) -------------> audio output jack plug or Optical in------->Optical out
Thanks
Posted on Sep 05, 2009
SOURCE:
Can i connect my router to my hdtv?
Yes you can connect your HDTV to the router. If the TV has Ethernet port then you can connect the TV to the router using an Ethernet cable. Moreover, if the TV has wireless capabilities then you can even connect the TV to the wireless network of the router.
Regards
Anand
Oct 10, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I can not get my wireless router to find my or take my ip address
Your wireless router once you connect to it will give out an IP. You can only setup in the router software what your machines MAC address and preset it to be given an IP of your choice.
So in short your wireless computer should find the wireless router via.. SSID and its password then once authenticated your machine will be given and IP and gateway to access your network.
If you are having trouble connecting to the wireless router. Then I suggest connecting to it via the wire first make the needed adjustments and then retry the wireless connectivity.
this link will bring you to the manual for your router http://www.dlink.com/products/?pid=DIR-615&tab=3
GL
hope this helps
Don
Aug 08, 2011 | D-Link DIR-615 Wireless Router
Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 03, 2010 | D-Link DIR-625 (790069292637) Wireless...
Not reading wireless connection
The wireless router needs its wireless settings configured and also the wireless card in all the laptops and or computers needs to be configured with the router’s wireless settings so the laptops and desktop computers can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 15, 2009 | E-Machines T5048 (7136) PC Desktop
I have a netopia wireless router, I've just had comcast install the internet however I would like to install the router. the modem to my computer accommodate only one ehternet cable at a time and it...
You can connect your computer to Internet if you have a Wi-Fi card in the computer. You need to connect the modem ethernet cable to the netopia wireless router and then connect to internet through wireless connection. First task is to configure wireless network connectivity on your netopia router connecting the 1st ethernet port to your pc lan card port, you will need the netopia instruction manual for this. The wireless configuration will be through a browser window(like internet explorer/mozilla firefox). This may take roughly 20 -30 minutes.
Jul 25, 2009 | Computers & Internet
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
No internet connection with laptop computers in home
Good day!
If your Desktop computer is hardwired to the router and your laptop computers can't connect wirelessly, it could be your wireless computers are not synchronized with your router by not having the same settings as the router.
You can use the desktop machine to access your router web interface (setup page) to check the wireless settings such as SSID (Network Name-> Name of your wireless signal shown on your laptop computers), channel and security (wether it is WEP or WPA encryption)
The channel and network name will be automatically detected by the wireless computers. If you have an encryption/security on the router, you need to type the password on the wireless computers for them to authenticate.
Try these and post back if there's any progress
Aug 03, 2008 | NetGear : WGT624 108 Mbps Wireless...
I'm having problems going wireless
What process have you followed to try to connect to the network and access the Internet? Where does this process fail?
Apr 13, 2008 | Belkin (F5D7230-4) Router (587009)
I have purchased a Belkin Wireless G Router for a cable modem. I have installed however i am unable to see the wireless network. What have i done wrong ??
Hello experts....
My problem is not being able to work wirelessly with my laptop. My answers to your questions are underlined(I've used your questions to someone elses problem)
One possible issue is your router's wireless radio is not enabled- the light on the router is lite on the symbol for wireless
or the wireless radio is not enabled on the computer you are attempting to connect to the router with - there is a switch on the front of this machine which is switched to wireless.
There are many other possibilities as well. That is why we need you to carefully answer EACH ONE of the following questions.
(01) Which of the following is your router?
-->> F5D7230-4 (Wireless G Router)
(03) Are ANY of the computers connected to your Belkin router able to access the Internet?
YES
(04) If there are other computers connected to the router that are able to access the Internet, how are they connected? (in each case, please)
only this machine is connected but it is by....
(b) wired (using an Ethernet patch cable connected between the router and the computer)
(05) What is the manufacturer and model number of the computer you are attempting to access the Internet via the router on?
HP Pavilion dv2500
(06) What operating system is installed on the computer you are attempting to access the Internet via the router on?
This machine is operating on Vista but the internet access I have is with talktalk
(07) Have you ever successfully connected (wirelessly) to the Internet from the computer you are attempting to wirelessly access the Internet through your Belkin router on?
NO
I hope you don't mind me using your questions to someone else, I thought you might be able to figure out what I'm doing wrong. I am connected to the internet but don't seem to be able to work wirelessly. Lorraine
Apr 09, 2008 | Belkin (F5D7230-4) Router (587009)
E-Machines eMachines Desktop PC Logo
231 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
