Question about Vacuums
We have model number 116 369 32502
the front beater bar brush does not rotate
help!
  • 430 Answers
I`m guessing this is a Kenmore. If you can hear the motor running inside the head you need a new belt. If there are no visible screws underneath the hea at the front area where the brush sits,gently squeeze the sides of the light housing and you will find it pops off to expose two screws. Undo them and the lid will pop off the main body. You can find a replacement belt at sears or vac specialt shop. check to see the brush rolls freely and no hair is caught under the metal caps. There is a spacer washer under the caps on the end of the brush. DO NOT LOSE these.
Posted on Sep 06, 2009
Where is the beater brush on a hoover max extract dual v
It does not have a beater bar. Under the front nozzle assembly is the brush block assembly which has 5 Or 6 rotating brushes which help to disperse the water and agitate the carpet.
Feb 16, 2018 | Hoover Vacuums
Brushes will not turn around. Can this be a ez fix?
Without knowing the brand and model number, I can't assist too much. However, most all of them have a belt that turns the rotating brushes or "beater bar".
It looks like a large black rubber band, and does wear out at times causing this condition. It would be located under a removable panel on the bottom of the unit.
Also check to make sure there is no dirt or strings preventing the brushes from turning.
Jan 06, 2017 | Vacuums
Electrolux Z61a brush not rotating
There should be a rubber belt somewhere along that roller, probably in the middle, behind the bottom cover plate, Remove the plate. That belt may have just slipped off the motor shaft, but it may be broken.
The belt could possibly be installed in either of two ways. The motor shaft is not parallel to the beater bar (brushes), so the belt must twist to wrap around both the motor shaft and the beater bar. If it's twisted one direction, the beater bar will rotate the correct direction (as if drying to pull the vacuum forward). Twisted the wrong way, it'll rotate the opposite direction. Try it one way, then bump the power switch to verify that the brush is rotating the correct direction before putting the bottom cover plate back on.
Aug 10, 2014 | Electrolux Vacuums
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
My vacum will not pick up, it is spitting the dirt out?
Check for blockage.
Most likely place is in the tube leading up from behind the beater bar. While unplugged, remove beater bar & belt & check.
If you have a strong shop vac, remove beater bar, belt, and bag, applying suction to the tube in back of the beater bar will many times dislodge the clog with little effort, sometimes though it will take some fishing around with a stiff piece of coathanger wire or similar.
Normally when you can apply suction with the shop vac to the tube in back of the beater bar & feel suction at the tube were the bag connects, you know you've got it all and you should be unclogged. Put it back together and you should be ready to roll.
Feb 11, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Kirby Heritage II. Beater bar does not turn. One end rotates freely, but the other sticks, preventing the bar from rotating. No obvious means to disassemble the end of the bar. Is there a way to repair...
The bearing is bad on the end that turns hard. You will need to purchase a new brush roll assembly. If the roller is older that 4 or 5 years, it should be changed anyway. The brush strips that scrub the carpet loose their strength after many years of combing through the carpet, so it's a good idea to change it every 5 years or so.
Oct 03, 2009 | Vacuums
No suction from base or hose attachment
I had the same problem with my Eureka vacuum cleaner. I don't have the problem with the beater bar, but I had the problem with the attachment hose not getting any suction. I found out that I was putting attachment on the wrong end of the hose. The end that you use in the front. Don't how I got that confused because it always worked before. Hope this helps with the hose part of the problem.
Glen
Mar 19, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
183 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
