Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa c250 mp3 player connects and will not charge
My mp3 player is recongnized by my computer and looks like it's charging, but when I disconnect it does not turn on/does not show that it charged at all. Please Help
    Problem Solver:
  • 7 Answers
It takes a while. Try leaving it charged over night, then tell me if you have any problems.
Posted on Sep 05, 2009
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
What is the proper time line to charge my Sansa c250 battery
i herd this worked for sansa players. if u right click the player in my computer on a pc than chose propertys it will show batter charge.
Jun 23, 2009 | SanDisk Sansa Fuze MP3 Player
My Sansa c250 won't charge properly. Initially when I bought it, I used it with a Windows XP PC, no sweat. That computer died and I began charging it with an OSX instead. It worked for a while, but after a...
I had a similar problem. My Sansa c250 would charge, when plugged into the computer. It would read that it was writing but the computer did not recognized that the Sansa c250 was connected. I switched to a different USB port and got the same results. I then realized that the two ports I was using were 1.0 port and idmedeatly when inserted in the 2.0 port it began charging and the computer recongized the Sansa c250. I know this won't solve every charging problem one may have. Changing the battery would be easier in some cases. Especially if they were sold like the AA or AAA.
Jun 08, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Music not synchronized
Try going to the actual file the music is in on your computer, then right click Send To sansa 250. If that doesn't work look on the options menu for USB mode and change it, that works on my 280.
Oct 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Help plz
What op system are you running?
Aug 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Jul 21, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250
Get a USB cord and connect it to the computer. It will automatically charge with no software installed on your computer.
Mar 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
83 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
