Question about Pioneer VSX-D514 Receiver
Overload... I have had the VSX D514 for about 3 years. It has been great with out problems. Recently, it has started to flash "overload" and then simply shuts down. Sometimes it will work for an extended period, other times, it will turn on and immediately flash overload and shut down... it happens whether the unit has been on for a while, or if it has been turned on for the first time in the day. Any help?
  • 4 more comments
  • blondul79 Feb 11, 2008
    same pb. that overload is making me crazy.
  • Anonymous Jul 27, 2008
  • mgm260 Mar 07, 2009
    Hello to all.  I have had the receiver for a few years and it has worked fine.  I was jamming the other day, rather loudly.  I have 100 watt speakers and the Ohm setting is on 8.  I have begun receiving the overload signal and the stereo shuts off, it is making me want to kick the **** out of it.  Any suggestions would be appreciated.
  • mikepmix Mar 10, 2009
    I've had this receiver for 4 years and the same damn thing, turn up the volume and it all goes to ****. Overload and shut down. My set-up has not changed. Same speakers over the past 4 years, 5.1 KEF. Please help!!
  • Anonymous Mar 17, 2009
    mikepmix,  You are the man.  I have had my Infinity speakers for 10 years and the same receiver, all of a sudden I started receiving an overload signal.  I bought two different receivers thinking it was them, returned them.  Got po'd and kicked the **** out of my beloved Pioneer.  I just tried what you said, both speakers on overload signal. Unhooked the right one, overload signal.  Unhooked the left one, no signal and I am jamming at max volume.  So apparently it is the left speaker.   You are the man, thanks a lot, Mike.
  • mgm260 May 11, 2010
    I tried sonofdetroit's suggestion and the thing is doing the same dang thing.  Please help, before my beloved Pioneer receiver is destroyed.  Thanks
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Posted on Mar 10, 2009
    Problem Solver:
  • 6 Answers
If I remember correctly, that is too much draw from the speakers.
Use smaller speakers, or try disconnecting two speakers to see if the "overload" problem goes away.
Posted on Aug 05, 2008
Power overload
That is a good thing, your receiver is going into "protect mode" that means the receiver is shutting down to keep from damaging delicate internal circuitry, it is sensing a speaker bottoming out or some other electrical "short" that could be damaging!
Also could be from over driveing the amp and then it starts to overheat thus going into "protect mode".
If your speakers are "clipping or distorting" turn it down, you are going to ruin your amp. Good luck !
Jan 06, 2010 | Pioneer VSX-516-K
VSX-D608 Overload and shutdown
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Jun 22, 2009 | Pioneer VSX-D608 Receiver
Vsx-517 keeps going into overload mode!
Try this:
1. Turn off the receiver.
2. Disconnect all the speakers from the back of the receiver.
3. Turn on the receiver. Does it still go into overload? If so, it may need repair.
4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
Apr 20, 2009 | Pioneer VSX-517
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
VSX-D498 Overload
if you have an EQ hooked up it will not work correctly with dolby digital playback and will dammage the reciever.
sorry, just got here , but I have the same unit and have had it for 5+ years and it still works great ! but if you want any device to last unplug it when you are not going to use it for a while.
Dec 22, 2007 | Pioneer VSX-D498 Receiver
Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Dec 04, 2007 | Pioneer VSX-D608 Receiver
Overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Nov 26, 2007 | Pioneer VSX-D307 Receiver
Overload?
I was recently on the Pioneer site researching this receiver. They just happen to have a few suggestions for trouble shooting this particular problem. I think you have to have cookies enabled to view this link. Hope it helps ya. http://www.pioneerelectronics.com/pna/v3/pg/support/knowledgebase/0,,2076_310069579,00.html
Sep 08, 2007 | Pioneer VSX-D608 Receiver
Overload message
chnage de golden connectors (if that's what you are using) that you use to connect your speaker wiring to your speakers if they seem damaged. that's what i did
Aug 26, 2007 | Pioneer VSX-D510 Receiver
Overload
That same thing happened to me a few months back and the problem was that the terminals of a speaker were not connected properly, check all of your speaker cables, or check for a broken speaker by setting the volume of each one and make sure they all work, you might find the problem there!!!
Jan 19, 2007 | Pioneer VSX-515 Receiver
Pioneer VSX-D514 Receiver Logo
1,114 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
