Question about Hitachi TravelStar DK23FB (08K1427) 40 GB Hard Drive
Ilooked up the spec on my computer from dell (that
I looked up the spec on my computer from dell (that isn't working anymore) and it said I had an IDE drive. I purchased an IDE 2.5 rosewill enclosure from newegg and the connections are not compatible. I looked up my hard drive (Hitachi Travelstar DK23FB-40) and it says it is an ATA drive or and IDE-ATA drive. What enclosure will work?
  • 62 Answers
U need a SATA (serial ATA) drive, buy a SATA drive and its compatible with most of the computers today.
u can read about SATA drive by clicking this link i am giving:
http://en.wikipedia.org/wiki/Serial_ATA
plz do not forget to vote and click yes if i solved your problem,thank u! :)
Posted on Sep 06, 2009
I have a component from Maddog Multimedia I am trying to install in a Dell computer.
As long as the drive has the right conectors (IDE & Molex I suspect)
It should be fine
Oct 01, 2014 | Computers & Internet
Bluetooth on sony vaio VPCEB44FX
Ilooked at the specs for your computer it does not list Bluetooth compatible, but that does not mean you don't have Bluetooth. Open the Control Panel, do you see the Blurtooth Icon? Is Bluetooth listed in Device Manager? If the Mouse or you have a Bluetooth USB adapter then yes.
Dec 20, 2012 | Sony VAIO EB Series Notebook
I dont have a hard drive, can i use any hard drive
I looked up the specs on that device. See below. The specs call for IDE. You will only be able to use an IDE harddrive drive. You can pick IDE drives up pretty cheap from TigerDirect, Amazon, NewEgg or most local tech computer/tech stores.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
Oct 21, 2012 | Dell Dimension 2400 PC Desktop
The HDD 60 GB IS BROKEN. I NEED SPECIFICATION MANUAL. SERIAL NB. IS 43073907P.The HDD sounds a High Noize as mecha- ical unbalance .I lost all software including the PXE Boot startup. Can I Upgrad HDD...
It sounds like you need to get a new hard drive for your computer. Any IDE laptop hard drive should work fine but be aware that an IDE hard drive isn't that easy to find anymore. All new hard drives are SATA which is not what you would want. Any size should be fine.
Sep 08, 2011 | Toshiba Satellite 2455-S305 Notebook
I want to replace CD drive on Dell Dimension 8200. My options are serial ATA, parallel ATA & ATAPI. Which one do I need?
This computer has 2 IDE connectors. These are parallel ATA connectors.
See: Dell Dimension 8200 Specs
If you get a drive, look for IDE on the package. IDE, PATA and ATAPI are near synonomous. They use a 40 pin flat ribbon cable to connect.
Thanks for using Fixya.
Nov 25, 2009 | Dell Dimension 8200 PC Desktop
Dell E510 Missing CD & DVD Drives...nothing is working yet...
you can buy that type of hardware anywhere since it is standard for all desktop. Your current drive is IDE meaning that the data cable on it is an IDE type.
Go to your local computer store and ask for a DVD writer IDE, since there is really no price difference now for a combo or dvd writer drive, it will be like 10 $ more for the writer. I live in canada so if you are in the US could be less here a DVD writer is around 35 $ at a computer shop.
Here is the spec of your computer just in case :
Dimension E510
May 28, 2009 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
New hard drive choices
Hello, Bob!
Seeing as I am a 6 year veteran of Dell Tech Support, I should be able to help you out, no problem.
One thing that I would like to let you know is this: according to Dell Support Policy, you ARE allowed to put a non-Dell-branded hard drive in your computer. However, if Dell Support deams that this non-Dell hdd has caused another Dell component to fail, they will not replace the defective product. BUT, since it is HIGHLY unlikely that a non-Dell hdd would actually cause any other failure, feel free to purchase a non-Dell hdd. (I often times suggested that customers take this route because unless you're purchasing a refurbished Dell product, you're only paying for the Dell name.)
Anywho...
There really are no limitations to what size hdd you can install in your computer. Of course, a larger hdd will take more time to process information (Basically, there's more surface area to scan when your computer is searching for a specific piece of information.). Your main thing will be determining if you have an IDE hdd or a SATA hdd.
The Dell Tech website CAN be your friend (support.dell.com). From there, you can view original configuration and even available upgrades simply by entering your service tag (Usually found toward the back of your computer, on a black sticker with white text. It should list your service tag, an alpha-numeric value, and express service code, an all-numeric value).
If I were in your position, I would most likely not go over a 160g or 200g hard drive... simply to keep decent performance.
Hope I helped!
Oct 29, 2008 | Dell Dimension 8200 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Hitachi TravelStar DK23FB (08K1427) 40 GB Hard Drive Logo
131 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
