Static in speaker even after cleaning an plugging wire back in still crackles?I belive the speaker is blown.
  • 691 Answers
Fist test all speaker using different good working amp, so we can eliminate bad or blown speaks. second, make sure you hook up the right pole negative to negative and positive to positive, it very important that you do, otherwise you will short the unit real quick. next take the cover off the amp, get your self couple of can of dust cleaners and blow all the dust out real good. if everything is done and hook up properly than your amp is faulty. if you have no electrical back ground take it to the earnest electronic repair and have it done correctly.
Posted on Sep 05, 2009
Crackling and scratching
Your speaker may be blown take out the speaker that is hooked up and attach another one a house speaker would even work, and i bet your speakers are blow if not check the wires and make sure you have them connected properly if not check the wires going to the harness and to the speaker and if not i think the radio is fried you can also take a long speaker wire take radio out the dash and run it to the speaker if it does still the radio is fried take it back before 90 days is up!
May 29, 2013 | Pioneer Car Audio & Video
Amp crackling noise
Sounds like you could have a blown amp/speaker or you've got a short in your speaker lead. Typically, when there's not enough resistance on a wire is when you start getting the crackling noises.
Aug 06, 2012 | Televison & Video
Nakamichi mini speaker has crackling noise as soon it is switched on
check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 29, 2012 | Audio Players & Recorders
I get static and crackling sound out of right speaker, then it blows the speaker fuse, Sanaui au-999 what is wrong
Any of the transistors in the right channel power amp section circuit will have the fault. Check it. A very skilled work indeed.
Apr 15, 2012 | Audio Players & Recorders
Everything is plugged i correctly but every couple hours or so the speakers will be crackling and the volume will fluxuate until it becomes inaudible. What can i do to fix this?
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Apr 20, 2011 | Dell 5650 Computer Speakers
Speakers seem to crackle sometimes
hope this helps
Apr 09, 2011 | Logitech S120 2 Speakers
No sound from one tweeter
Could be an open capacitor in the cross-over, unconnected wire to the tweeter (not likely) or a blown (open) voicecoil in the tweeter. Remove the tweeter and with a 9 volt battery (even run down but not dead will work) quickly touch it to the connections to the tweeter - it should pop and crackle. No static, the tweeter has sung it's last song.
Apr 08, 2011 | Acoustic Research AR 318PS Speaker
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
50 people viewed this question
 Grubhead
Grubhead
