Question about Refrigerators
I needs to replace my refrigator door gasket. I need a manual with pictorial diagram and with details on how to remove and install the gasket.
Open door and pull on inside of gasket to expose screws or 1/4 nuts.. loosen[do NOT remove] all screws and pull old gasket out. place new gasket in sink of hot water to soften it and put back around door. snug up a couple of screws on each side and test seal by shutting door..you may need to adjust inner panel until just right..then tighten all screws
Posted on Sep 05, 2009
How to install water tank on GE side x side. I have the new tank to install. Need diagram of connections.
Hello.
I do not believe any diagrams exist on the web for such diagrams. Basically the way it goes is as such
The tank has a long line and a shorter line
the shorter line connects to the water valve on the back of the refrig.
the longer line runs underneith and connects to the connector behind the freezer door lower hinge cover or that area by the lower freezer door hinge. depending on age of refrig. that fitting the tubes connect to unscrew or on newer models the collar on the inner part of the connecter is push in while pulling out tube to remove old tube
Aug 17, 2011 | GE Refrigerators
How many cu ft is it? need new seal for door hmg241770 admiral refrig
Not sure what the cubic feet for the doors for that refrig. but i have the part#'s for you
Fresh food gasket 61004010
Freezer door gasket 61004011
hope this is your looking for
Gene
Aug 01, 2011 | Kitchen Ranges
How do I replace door Gasket?
White plastic strip just to the refrig side of the center gasket needs to be removed first, then gasket pulled back enough to reveal gasket retainer. Use a flat bade screwdriver to pop out the white clips at the top and bottom allowing strip to be removed. Now gasket can be easily pulled out of groove. Be careful when re-installing clips to get springs in correctly.
Feb 19, 2011 | LG LFX25960 Titanium Bottom Freezer French...
I have the parts but need the instructions to install a new lock on my Asko frontload Washer/Dryer WD22M19.
Disconnect power then remove the clamp that holds the door gasket to the outer lip of the door opening. Once the clamp is off, peel the door gasket off near the door lock. Remove the screws securing the door lock to the front panel and take the lock out of the machine cabinet. Transfer the wires to the new lock then install it into place. Put the door gasket over the outer lip of the door opening and secure it with the clamp to complete the repair.
Oct 25, 2010 | Asko WCAM1812 Front Load Washer / Dryer
I have a 1995 dodge dakota. I need to replace driver side door. Need to know how to take door off properly. Need diagram or something. HELP.
Removal & Installation
  1. Matchmark the hinge-to-body and hinge-to-door locations. Support the door either on jackstands or have somebody hold it for you.
  2. Remove the lower hinge-to-door bolts.
  3. Remove the upper hinge-to-door bolts and lift the door off the hinges.
Details of a common door assembly-Dakota shown
Click to Enlarge
To install:
  1. If the hinges are being replaced, remove them from the door pillar.
  2. Install the door and hinges with the bolts finger-tight.
View of the door hinges-1994-96 Pick-ups
Oct 23, 2010 | 1995 Dodge Dakota
I need to replace the door gasket on a Whirlpool refrigerator ET8WTMXKQ01. The gasket appears to be held on by the liner but there are no screws in the liner to take it loose or off. Any ideas?
It has a clamp I beliece and it just slides out but you can go to appliancepros.com online and look up that model and it will show you exatly where the screws are if there are any. Most have screws in the corner onlt and others have none at all, and if you don't have the gasket you canorder it there also.
Nov 12, 2009 | Refrigerators
How do I change the gasket on the refrig door? Freezer above the refrig. The refrig is a Magic Chef with the freezer above the refrig.
take the door off the fridge fold back the gasket to expose the screws remove all the screws put on new gasket put screws back the trick is to keep the door very flat or it will warp or bend it is not hard just remember the trick...good luck..
GAR
Aug 04, 2009 | Refrigerators
INTERIOR FRIG LIGHT
replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
Oct 22, 2008 | Frigidaire FRT21H8 Top Freezer...
Mita DC-1205 Copier
Open the front door... on the right is your toner. It is a cartridge that inserts long-ways (front to rear) into the machine, and should be white or ivory in color. DO NOT remove the old toner cartridge without having a replacement on hand. The new cartridge will have a plastic "cover" on it that assists in releasing the toner cartridge locking tab, and "seal" the old cartridge as you remove it from the copier. The cartridge opening is face down upon installation into the machine, and you may get some spillage if you remove it without the cover. DO NOT remove the new cartridges mylar seal until AFTER you install it in the machine!!! There should be a picture label inside the front cover showing how to replace the cartridge. And there is a pictorial diagram on each new toner cartridge box also detailing this.
Use only MITA DC 1205/1255/1415/1435/1455 toner, OEM #MTA37041013. Should run you about $12-$14 per cartridge retail, or cheaper if shopping around (I sell them for $11.99). Do not use copystar brand for the same equipment. Although it's the same toner, the shape of the cartridge is slightly altered, and may not "fit" into the machine. I forget how it goes, either Copystar will work in Mita, and not the other way around, or vice-versa. Either way, better safe than sorry.
Oct 24, 2007 | Office Equipment & Supplies
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
