Question about Jl Audio 500/1 Car Audio Amplifier
What is the color code for the jl audio 4 channel rca need to what the black and gray r for
    Guru:
  • 1,326 Answers
Color code for what? RCA's are red/black for audio. Their should not be a black and grey RCA. Where do the wires come from/go to??
Posted on Sep 06, 2009
Rca wire colours are
The most common colour convention is:
Yellow: Video
Red: Audio, right channel
White (or black): Audio, left channel
Green; Centre audio
Blue: Left Surround
Gray: Right Surround
Brown: left back surround
Tan: Right back surround
Purple: subwoofer
Sep 13, 2013 | Car Audio & Video
I recently got a JL 300 amp and at first the sub stopped working, then it came back on during the song I was playing. Later on it shut off all together. I don't know what the problem is..
Does it only happen on that channel. It is a 4 channel amp so make sure the other channels are working. It sounds like an RCA input prob. Try the sub on the other channel. if it works then it would be your RCA input needs resoldered.
Sep 04, 2011 | Jl Audio 300/4 Car Audio Amplifier
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
What color is the manual for the 500 1/v2 jl?
the manual is black and white and has 13 pages, but you say you have alot concern that the amp was used, if so you should give onlinestereo a call and let them know. just get the model and serial number from off of the box they came in.
Feb 20, 2010 | Jl Audio 500/1 Car Audio Amplifier
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
Jan 13, 2010 | Jensen CD4610 CD Player
I need the wire color code for the clarion db225 ,so i can install it .
Red = switched 12V
Yellow = constant 12V
Black = ground
Blue/White = power antenna
Speakers are a color set, one with a black stripe
White set = left front
Gray set = right front
Green set = left rear
Purple set = right rear
The RCA plugs are pre-amp out.
Dec 27, 2009 | Clarion DB-225 CD Player
What do the color codes represent on the outputs on a Clarion VRX765VD?
Hello davetk76,
Here's the color code for the RCA outputs: Gray - front; Black - rear; Violet - non-fader (subwoofer); Green - 2-Zone; and single gray with yellow plug - video out.
If you do not have the manual, I'd recommend that you go here to Crutchfield and download a PDF copy. Save it to your computer and print out pages 72-73 which has all of the wiring.
Hope this helps.
May 25, 2009 | Clarion Car Audio & Video
Wiring problem
grays are right channel and greens are left. The red stripe and large back stripe are for rear channels.
Apr 14, 2009 | Car Audio & Video
Help
If you are asking about the common RCA type plugs and sockets, The common colors are: WHITE or BLACK is for left audio channel. RED is right audio channel. Otherwise, clarification is needed. :?
Jan 20, 2009 | Car Audio & Video
JL 300/4 problem
If both the left front and left rear channels are out, reverse the RCA cables to determine if the problem is signal related. If the left side plays when you reverse the RCA cables, reverse them at the head unit to see if the audio changes sides. If it does, the head unit is likely the problem. If it doesn't switch sides when you switch at the head unit, the RCA cables are the problem.
May 22, 2008 | Jl Audio 300/4 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
73 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
