Question about Motorola EM1000R Two Way Radio
Motorola gm300 my motorola gm300 can send but rcieve very soft.
  • wp4k May 11, 2010
    Hope you had solved your problem, i just wanted to add a bit of info...
    I had used/repair/installed/modify quite a bit of motorolas( HAM Operator for 25yrs) and that gm 300 was one of the trickiest... I used them for both mobile service as well as Repeaters( 2-units thru controllers)...
    They are very solid and stick to the programmed frequency, so here are my .2cents, go back to your programming and verify you are ok there, band-segments/tone/dcs usage/squelch level and the antenna system...
    good luck...
    kilo
    Brigadier General:
  • 6,966 Answers
If you are referring to the receive audio, possibly the reason it is soft/weak are:
1. defective internal speaker - try using an external speaker;
2. volume control - try rotating back & forth till you get satisfactory level. In some cases, you may need to clean the inside of the volume control with an electronic contact cleaner. At worst is that it has to be replaced;
3. defective amplifier - between the volume control and the speaker is the audio amplifier. This is a single op-amp IC U501 (TDA1519A); and/or
4. muting - which is a bit complicated. This is triggered either by the squelch or by the CTCSS tone decoder. You may have partial/false muting. You need to check Q501 (MMBT3904) and its associated circuitry.
Other than #1, most fix would require opening the unit and familiarity with electronic circuitry & components, use of a DVM and soldering iron. Perhaps your best bet would be to seek the services of a qualified communication technician.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 08, 2007
Can you give me the specs on: Motorola radius GM300 radio? Model: M43gmc29c2aa wanting to know how many channels and how many watts. Thank you.
I think this is what you are looking for: Motorola Radius GM300 VHF 146-174mhz 16 channel 45 watt mobile (MDL# M43GMC29C2AA)
Jul 11, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola gm300
you mean a low volume?
if so try to set it higher (can't be difficult)
Dec 08, 2007 | Radio Communications
Does a motorola gm300 model number m43gmc29c2aa have ctcss or PL TONES capability's?
Yes, it seems to me that the GM300 radios did have tones as programming options. They were programmed by the dealer using radio service software (RSS) when the frequencies and other channel information were entered. Of course, Motorola discontinued the GM300 a long time ago, and they were wide-band radios, so you could not legally transmit with them anymore. However, you could find someone on eBay to program them receive-only with or without CTCSS (PL) tones and then you could simply listen to them.
Jun 24, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Hello Guys..how to channelize my 2way Radio Motorola Radius Model
The GM300 is dealer programmable using Motorola proprietary software, a programming cable and radio interface box (rib). (Or on some models a ribless cable). I will continue to look for a user guide pdf. If I locate one I will post it.
May 01, 2009 | Radio Communications
How to change frequency on gm300
To my knowledge the GM 300 can be programmed only with a DOS based programing software. Start with the DOS, not from the windows
Mar 12, 2009 | Motorola GP300 Compatible 2 Way Radio...
2 way radios
Your radio with model number M33GMC09C2AA is a GM300 made for Central Asia, Eastern Europe and Turkey. It is VHF 25 watt with 12.5 channel spacing. It will do frequencies between 146-174 MHz. It should be able to be "read out" by a Motorola dealer. If it has been in a boat, it most likely is programmed with Marine frequencies. If you have another marine radio you may be able to determine the frequency by process of elimination.
The wiring kit for power is readily available for around $18 ea. If your boat has a marine VHF antenna onboard, you will be able to attach the antenna to this radio. It takes a mini-PL connector.
Sep 14, 2008 | Motorola Radio Communications
Motorola GM300 Question
Check your antenna connections and coax for loose connections or damage. Also check your hand mic. See if the problem disappears if you turn on the radio without the mic attached. The two most common problems with a mobile radio are antenna and mic problems.
If you feel these are in order, it would be wise to have a tech look at the radio.
Aug 23, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Problems setting up Motorolla GM300
It is either a programming problem, such as the Rx is not programmed correctly OR your radio needs to be looked at by a technician to determine the issue.
Jun 14, 2008 | Motorola GP300 Compatible 2 Way Radio...
Motorola EM1000R  Two Way Radio Logo
473 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
