My washer is losing water onto the floor. I have
My washer is losing water onto the floor. I have checked all hoses and the wall drain and can find no place where it leaks. Any ideas?
  • 39 Answers
Right on the side of your backet, inside your washer you have a water level control system....
What kind is depends on the brand..
check it...you washer just don't know when to stop..or stoping to late
Posted on Sep 05, 2009
My washing machine keeps filling with water
If the washer keeps filling up without overflowing onto the floor , then you have the drain hose too deep into the drain and it is siphoning, pull the drain hose back up from being so deep and have it only about 10 inches into the drain, tie it into place with a shoestring or wire tie.
Now if your problem is that the washer is overflowing onto the floor, then there is a clear rubber hose that has been disconnected from the washer, this is the diaphragm hose. Have a technician reattach it. It shuts the water off and starts the machine when its gets enough water, but it wont if the hose is disconnected. Mr Burk
Feb 15, 2015 | Washing Machines
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leak at back of machine
A leak at the back of a washing machine can come from several sources.
It requires a good investigation.
Here are some of the first area to look at that are on the outside of the machine
1 Hot and Cold Fill Hoses may not be tight enough. So water can drip down the hose, or back of machine onto the floor
2 Drain Hose-Usually about an inch or so in diameter. Hose in new machines should not leak itself, but if it is not mounted or attached well enough into the drainage plumbing mounted on the wall (The box with the Hot and Cold Water Shut-offs, it will leak or splash water onto the floor during the drain cycle.
3 Damaged plumbing in the wall can seep under the wall and end up under the washer. This is very rare, but I have seen it.
4 There is a filter mounted behind a panel on the lower back side of the machine. It is possible a leak is occurring from that area. Take off the cover and see.
If the above don't handle it, the next step is for what is not easy to detect. Leaks inside the machine. You will need to go into it and LOOK with your eyes and a good flashlight.
Hope this helps,
Best, Mark
Dec 31, 2010 | Hotpoint WMA54 Front Load Washer
Replace washer for hose - washer leaks
You have to determine if the water is coming from the hose connections. If not, check that the water supply that feeds into the basket hasn't been moved out of place. Is this a new washer? I have seen cracked outer tubs-they are just plastic.
Nov 08, 2009 | Whirlpool Washing Machines
Water pours from drain hose overflow in front of washer
That drain hose in front has a stopper, to prevent discharge. Either it is not there or not tight or something. You can always clog it shut with a round wood bit inserted or something........I don't think it is too difficult.
May 08, 2009 | LG WM0001HTMA Front Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Ld error code won`t drain.or do anything starts for 10 sec and stops
Owner manual - Code Ld -says the drain hose is kinked or clogged.
Check that the hose didn't get kinked when pushed back to the wall. It's a common problem. The problem is NOT the wall drain as water would be coming out onto the floor if that was the issue.
Jan 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag performa washer
check to see if the tub to pump hose has pulled off
Dec 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Admiral washer
Check from where does the water come? From the bottom of the machine or from the the drain plumbing tubing?
Nov 15, 2007 | Washing Machines
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
