Front display controls don't work (including power). Works perfectly by remote only (on/off, display lights, all remote functions work and display properly.) I could have sworn there was a display lock-out feature but, I can not find info in any manuals?
Sounds like the same problem I had with mine. I had to call and get an RMA number and they replaced the key pad, lcd display, and main board. This repair was covered under warranty. (Under 3 years old) They had it repaired and returned in about a week.
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi...
(More)
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi is that?
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest...
(More)
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest fresh air
I have 2 ecoquest fresh purifiers 1 will not power on would that be a fuse issue and the 2nd the...
(More)
I have 2 ecoquest fresh purifiers 1 will not power on would that be a fuse issue and the 2nd the sanitize mode won't work would that be a starter balas(ms)???can you help???
