Question about GE WWSE5200B Top Load Washer
GE top loading washer Washer wwse5200- Agititation?
I noticed that the white load wasn't clean and after close attention I found out that the agitation spiral is not working (no agitation, the load sets there and nothin is happening). The spiral part inside the washer is rotating both ways freely and I believe it should not! May be a large load earlier broke the "hold" for this spiral and it is loose. It is not coming out, it is still in its original place and free to rotate as montioned both ways. Other than that nothing seems broken in the machine. It works excellent: soak, rinse, spins!
My question is what is broken; why isn't it working? How can I fix it?
How can remove this agitation plastic spiral to further locate if any thing is broken?
I appreciate your assistance.
It is a cast aluminum peice below the agitaror that costs about $50.00 from GE.
Posted on Nov 22, 2009
  • 39 Answers
It is a "trany" problem...just buy a new washer or it is a plastic cap inside that spiral part, that cap have groves...it is maybe goes bad....
GE as a brand has a lot of problem with washers, dryers, microwaves and fridges...and dishwashers so try to stay away of repairing or buying a new GE....
Posted on Sep 05, 2009
Ge washer won't let water spin out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
Where is the lint trap for a top load ge wash machine location
Their is no lint trap on that washer, GE washers are built to be sold at the lower end of the price scale and dont include features found on upper end appliances
Jul 23, 2011 | GE WBSR3140DW Top Load Washer
Our top load GE washer leaves a lot of suds when washing towels, even though I use a minimum of detergent. Also I notice that sometimes there is a tiny amount of water at the bottom when the load is...
If you recently washed a rug perhaps and it came apart a babys sock or something came apart then it sounds like the pump is part restricted and will have to be cleaned.
Apr 01, 2011 | GE WJSE4150B Top Load Washer
Our GE WSERR417FOWW washer is leaking (profusely)
Any solution to your problem? I am searching because mine started the same behavior tonight. I hope that you found a solution, and would be willing to share it!
Thanks.
Jeff jeffyr2@verizon.net
May 24, 2010 | GE WJRR4170E Top Load Washer
My ge washer shuts off at 19 minutes, but filter is clean
The rug backing may have gone into the pump (the white motor thing) you might take the motor out and flush it out if it is clear and it still won't pump out the pump needs replaced.
Feb 22, 2010 | GE Energy Star WCVH6260F Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Jun 08, 2009 | GE WBSR3140DW Top Load Washer
Front loading ge washer model wbvh5100hww
I had to have repairman out. He said it had a filter in front panel that needed to be cleaned. It was full of hard white stuff, like caliche dirt. He noticed I use Arm & Hammer Detergent and he said that was good, but don't use HE detergents because when they mix with city water, it causes an odor in washer. Thanks- Beth
Sep 14, 2008 | LG WM-2277HW Front Load Washer
Whirlpool Duet Front Loading Washer Imbalance causing front door not to close
Plug off the wall, open the top of the machine, check to see if any wires have come loose in the door lock area, tighten up.
Nov 14, 2007 | GE WBVH6240F Front Load Washer
GE WWSE5200B Top Load Washer Logo
288 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
