Question about Ovens
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Posted on Dec 20, 2010
Flavel milano e50 cooker the oven is.making a very loud rattling noise. But it is still working. Any ideas what the problem is.
It's not a fan oven, so there's no moving parts.
It must be a panel or component (such as a shelf) vibrating in the heat.
When it's cold have a good look at the inside & see if there are any screw heads you can tighten & any of the components which can be pushed tighter.
Also check the thermostat probes to make sure that they're not vibrating against the side or top of the oven.?
Best of luck
Mar 13, 2018 | Ovens
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
Whrre is the battery compartment for flavel cascade 50 cooker please
Flavel : Manuals
www.flavelappliances.com/Products/Manuals
If you've lost or misplaced an instruction manual to one of your Flavel products, don't ... Electric Fan Oven with Separate Grill ... 60cm Side Control Gas Hob.
Sep 09, 2015 | Ovens
The self gas ignition stays on and keeps clicking.
Request manuals and parts lists directly from Flavel.
Nov 04, 2017 | Stoves Ovens
Flavel milano e60 electric cooker
Element or switch is done. Try switching elements first to see if that is it....if not then the switch is gonzo. The switch works as a potentiometer allowing more or less electricity (current) through the element.
Dec 02, 2013 | Ovens
Cooker flavel milano 60 4 years old Oven working fine, but grill makes problms.may be i am not using right method. Actually every thing is fine, but when i start grill and close the grill door its fir
Hello, you're probably not getting enough air in to keep the flame sustained, check for an outside air tube that might be clogged, if not than try keeping the door a crack open. Hope this helps
Oct 19, 2012 | Ovens
Flavel milano 60 manual
Keep in mind that Flavel Ovens are built by Leisure CP. This link could helpfull: upl/26348-Range60Leaflet.pdf
If this information isnt help, this and other manuals could be find sending a request here.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 17, 2011 | Ovens
Instruction manual for a flavel cascade 50 gas cooker
i have a flavel cascade 50 oven i can light it with the pilot light but once i release the knob the oven does not stay alite how do i solve this
Sep 27, 2010 | Ovens
I need to know the circuit breaker fuse size for a flavel milano ML6CDS electric cooker and the cable rating
If your power suply is 240V and the power rating of the ovenis 9.9kw then the expected current consumption is 9900w/240v = 41.25A. Therefore this needs a 8mmsq cable or if not available in your area then use 10mmsq cable. And for the fuse or circuit breaker use 50A
Jun 14, 2010 | Ovens
Ovens Logo
575 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
