Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
The GH400 auto feed is not working, the instruction manual doesn't address this. Spool is B-D .065 prewound, inserted arrow up. Nothing gumming up the works, cog moves freely, spring is like new.
5 Suggested Answers
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
  • 87 Answers
SOURCE: i have a black & decker gh400 and the auto
You will need to buy a new feeder head, if your model's head unscrews, normaly when these stop working there is not much you can do to fix it.
Posted on Oct 20, 2009
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
NST1024 trimmer string come off spool when trimmer is turned on
Make sure the line is wound on the spool in the direction indicated by the arrow on the spool. If the line is wound correctly, the auto-feed mechanism may be damaged. You'll probably need to take it back to your retailer to get it repaired. Your trimmer uses .065 size trimmer line and can be purchased in bulk via PartsBuggy.com at discounted prices.
Oct 22, 2012 | Garden
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
My bump knob on my Ryobi elect trimmer turns although very tight and turns the bolt but is not undoing. Any solutions please
Oct 31, 2011 | Ryobi 15" Electric Factory Reconditioned...
I need to replace wire on an electric weed eater auto feed 15 inch
Hi deanko1
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 01, 2011 | Homelite Garden
Trimmer head line loading instruction
1. Remove the cap on the trimmer head, it unscrews.
2. The spool comes off, and on the inside of the spool there is a small hole, this is where you will start your trimmer line. It it will hold it in place while you wrap it. There is also arrows on the spool showing the direction that you need to wrap your spool.
3. Insert the line in the hole and start to wrap the line in the directions of the arrows, try to keep the line in rows, or else the line may bind and you will have to do it all over again.
4. Feed the line through the retainer and reinstall the spool by lining up the retainer and the slot on the outside portion on the trimmer head, the screw back on the trimmer head and you will be ready to trim.
Jun 29, 2011 | Husqvarna 28cc Gas Line Trimmer
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
How do I spool new line onto this unit? It has a dual feed. Craftsman Weedwacker 17"/25cc
look on the bottom of the spool and see if there is an arrow point stamped on the outside of the spool, then check if there is an arrow point stamped on the inside of the spool. If so line up the two arrow points and cut two pieces of line about 3ft long. Insert one line into the hole where line comes out and push it until it comes out a little hole on the bottom of the spool. Pull some out and there will be a very little hole (the size of the line) beside the bigger hole insert the end of the line into the smaller hole and then pull it tight. Do the same for the other side. Then twist the spool (like you did to align the arrow points) stop when you have enough line out to reach the line cutter.
Jul 27, 2009 | Craftsman 25cc Gas Line Trimmer
I have a weedeater brand weedeater and need to know how to take the spool off so I can wind more line on it?
if its the newer type all you need to do is grab the black knob at the bottom of the trimmer head and pull it carefully straight towards you and it should pop off
wind line on the spool in the direction the arrow shows you there is a small hole you put the line in to start the line before you wind it it is labeled .065 or .080
wind about 10-15 feet of either .065 line or .080 line and lock the line in at the edge of the spool and thread the excess thru the hole and push spool back on and pull each line until it unhooks from where you locked it in .
this is the directions to the weedeater heads and spools mostly used on this product.
if its two lines then pull out 20 feet of new line cut it and put the two cut ends side by side and insert the cut ends into their respective holes in the spool and wind in the direction of the arrow until you wind to the loop then cut the loop lock your lines into place and thread it thru both holes keeping the lines kind of tight and push the spool onto the housing as it snaps in pull each line to unlock it from where they were held so the bump feed will work.
hope this helps you
Jun 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
556 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
