Hi when i bluetooth a red flashing light appears and no printing happen
What is the meaning of the Red & Blue flashing lights on the printer?
Now your printer in Service Mode.
It's time to reset the printer.
Apr 09, 2016 | Ricoh Aficio SP 100 e Laser Printer -...
How to get my new Bluetooth set-up
So, what else can I tell you. You yourself have discribed that your headset is defective. So, being a new device, return it to be changed for a new one.
Jun 03, 2014 | Apple Cell Phones
I have a samsung gusto sch-u365 and i want to pair it with the plantronics 240
In case you have never paired your headset to another phone before, just by turning it on, it should enter the pairing mode, denoted by its indicator light flashing alternately in red and blue. Otherwise, i.e. if it was paired to another phone before, press and hold the call control button until its indicator light flashes alternately in red and blue. Then, on your phone, press the left softkey and go to 'Menu > Settings > Bluetooth > Add New Device'. After a little while, your headset should appear on-screen. Using the directional key, select your headset and press 'Pair'. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is successful, your headset should enter the standby mode (blue light flashing every few seconds). There might be an indication on your phone screen that a bluetooth device is connected as well.
Hope it works for you.
By the way, in case any (or both) your headset and/or phone user guides happen to be missing, feel free to download them from here (headset) and/or here (phone).
Anyway, please, let me know if you need further informations.
Best regards,
Carlos
Jun 10, 2012 | Plantronics Explorer 240 Bluetooth Headset
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Hi I have an emerson em227 bluetooth and haver lost the direction. I need the instruction to start the paring process
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on your phone' screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds).
By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards, Carlos
Jan 13, 2011 | Emerson EM227 Bluetooth Headset
My bluetooth /plantronics explorer-210, and it does't connect w/my cellphone ,flashing blue light,that's all,what I to do..,help me
Your headset must be in pairing mode, in order to be discovered by your phone. Whenever it is in pairing mode, its indicator light flashes in red and blue. If it has never been paired before, just by turning it on, it should enter that mode. If it doesn't, it is because it has been paired to ohter phones before. In this case, after turning it on, press and hold the call button until the indicator light flashes red and blue. Then, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make the application connect to it. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). You see, the pairing process between any two bluetooth enabled devices should be perfomed just once. All subsequent connections should be achieved by bringing them with each other's reach (with their bluetooth radios turned on, of course). At most, a simple press on the call button should do the job.
Hope you are able to sort your problems out soon.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Hbhpv708 when i press any button the red light glows the headset is on phones will recognize the headset but connecting to it will fail resetting also not working
Hi, Before any bluetooth will connect to any phone, the red or red and blue light must flash back and forth. Make sure you're phone is in the set-up mode to recognize the phone. The easy way to do this if you dono't have directions, is to get the name and numbers off of the bluetooth and go online to find it. It will walk you through the steps to connect it to your phone. I have done this with many different models if all else fails. Give it a try and let me know what happens. This will solve you're problem,
Shastalaker7
Jan 29, 2010 | Sony Ericsson HBHPV708 708 Bluetooth...
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Flashing Green and Red lights
i querried from epson site it says the ink is low, repalce cartridge
Step 1 WHICH MODEL ARE YOU USING? Stylus C44UX Step 2 What were you doing when the problem occurred? Turning on the printer Step 3 What happened when you were turning on your printer? An error appeared on its control panel Step 4 What is the power light's current state? Flashing Step 5 What is the error light's current state? Flashing Step 6 WHAT IS THE PRINTER'S STATUS? Ink low
Oct 28, 2008 | Epson Stylus C44UX InkJet Printer
Compatability bluetooth headset K 750i/K800
Hi, The way that I paired my device is by pressing and holding the two volume buttons simultaneously for about 5 seconds, until the red and green lights began to appear. Then, i just 'refreshed' my bluetooth search for devices, and it discovered it, and was able to pair it up. Hopefully, this is useful
Oct 18, 2006 | Sony Ericsson HBH-610a (Auto Pairing)...
52 people viewed this question
k24674
