Question about Garden
I put the tractor in nuetral with the engine off and can't push it because it feels like it is till in gear
  • Chuck
    Chuck May 11, 2010
    Isit a stick or a hydrostatic
    Problem Solver:
  • 5 Answers
If it's hydrostatic it wont move you need to find the dump valves to release the pressure these are located around the drive wheels
Posted on Sep 15, 2009
94 Mazda B 2300 truck 5 speed transmission in nuetral and can't put into any gear
can be a normal situation as the teeth ends hit each other and will not mesh
not noticed if the engine is running as the teeth are moving
have you seen the clutch lever moving or are you just assuming it is good
probably didn't/doesn't need a clutch but a clutch master cylinder
Feb 23, 2018 | Mazda Cars & Trucks
Touro riding mower can u push this mower by hand
hydro-static mowers, you will not be able to push. if it is a gear-driven mower (if you need to put it in 1st, 2nd, 3rd... etc) then you should be able to push it when it is in nuetral. if not, then check the shifter linkage for binding. all riding lawn mowers now have seat switches that will shut the engine down if there isn't anyone in the seat.
Oct 18, 2014 | Garden
Hello, I have a John Deere 6810, built 2000 and the next few days problem.In not turned by electrical engine. if I go directly to the electric engine starts,but do not go on before and back.I doubled
start engine get the rear wheels off the groud push forward on the pedal then keeping rocking wheel forward till it goes into gear this take up some time but it works
Aug 29, 2014 | Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
I have a 1999 suburban with a 5.7 vortec the engine wont build rpm while moving,but revs freely in nuetral or park.If the computer senses movement in forward or reverse the engine misses such as a rev...
The computer can't sense movement. An engine with worn spark plugs or bad coils can run perfectly fine at idle and begin misfire the second you put it into gear or under loads. Plugs/coils misfire most when under load. Have you checked them?
Oct 18, 2017 | 1997 Chevrolet Suburban
Lawn tractor won't move when put into gear
First, check the tension of the drive belt. There should be an idler pulley which is spring loaded that creates the tension. When you push the clutch in, it will release the tension. Also, check to see if the rear wheel hubs have set screws which lock them onto the axle Make sure they are tight.
Aug 02, 2009 | Craftsman Garden
Ichanged the rear drive belt on my 17 hp
Ok, I see it's and MTD product. Did you replace both belts? The front belt is #954-0280 and the rear belt is # 954-0370. What I would suggest is remove the cover plate between your legs. You'll have to remove the shift knob and two screws. Start the engine, put the gearshift in nuetral and let out on the clutch pedal and observe what's happening. Everything will be working the same as if you were in gear. You should be able to see if there is a problem with one of the belts or the vari-speed pulley. Put the speed selector in 7th (or 6th) gear and push the clutch down then back up, and watch what going on. That's the best I can do without seeing it myself. Hope this helps.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
