Question about Dryers
Where is the service panel for the Whirlpool Duet Dryer GGW9200LQ1?
  • 1 more comment
  • dosgriffins Sep 05, 2009
    I have a burnt smell coming from the clothes in the dryer. I read on this site that one suggestion was to stop using dyer sheets; I never use them. The second suggesion was to open the "service panel" and check to be sure there was no lint near the heating element. I'm not sure where that is. Thanks for your help, Tom!
  • TomZS May 11, 2010
    If your trying to get to the main control board it is under the top.three screws in the rear.
  • 220 Answers
In the front on the bottom there are three to four 1/4 in drive screws in it.make sure you unplug it before you poke around with a vacuum in there,when you open it up you'll know if it was burning the lint is ususally gray in color will be black and charred.
Posted on Sep 05, 2009
Testimonial: "That did the trick! My model only had two drive screws. There was a lot of burnt lint near the heating element. Thanks Tom!!"
What does the error code E04 mean on Whirlpool AWU610 Washer-Dryer
Any error code starting with "E" followed by numbers indicates a code meant for a service technician. Call your Duet dryer retailer or Whirlpool directly to set up a servicing appointment.
Read more : http://www.ehow.com/list_7528706_whirlpool-duet-dryer-error-codes.html
Mar 16, 2015 | Whirlpool Washing Machines
On Whirlpool duet steam front loading DRYER...What does the error code F70 mean?Do you have to have a certified whirlpool appliance service professional to repair?
F70 code says...
Replace the machine control electronics. You should first unplug the machine and then remove and plug back in all connectors on the front panel model as well as the electronic control module.
If that doesn't take care of the problem then it may be time to consider replacing the rear board. The FSP # 8183259
The control board is part # 14 in the link below.
Sears parts direct /Whirlpool-Parts/Model-WFW9400VE01
Mar 13, 2015 | Whirlpool Washing Machines
Remove front plastic control panel of my Whirlpool duet dryer
Remove knobs and screws and then you should be able to pop it off
Nov 23, 2014 | Whirlpool Washing Machines
How do I clear error code F-28 on my Whirlpool Duet Sport electric dryer?
The tech sheet is located under the kick /service panel in a jacket. Suggetions and codes are in it. Duet sport service manual
Sep 30, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
What does F-1 mean on a Duet front load dryer? Our dryer's lights will turn on but, the dryer will not start up. At first we thought the control panel was locked out. But, it wasn't.
The "F-1" error code means a failure occurred with the electronic controls.. This could mean that wires are broken, the electronics shorted out or a manufacturer's default error shut the washer down.
Prevention/Solution: The electronic control panel needs replacement. Find your dryer serial number and search for the part online. This is a lengthy job that usually requires a repairman unless you have dealt with and repaired dryers before.
If your dryer was purchased within the past couple of years, the dryer could be covered under the warranty. Visit the Whirlpool customer service page for more information or Whirlpool-Duet-Dryer-fault-codes
Hope this helps.
Jun 02, 2011 | Whirlpool GEW9250 Electric Dryer
F 01 error code whirlpool duet dryer. Can I replace the control panel?
Where is the thermistor on the dryer on whirpool duet or remove control panel
Feb 28, 2011 | Whirlpool Dryers
My whirlpool duet dryer beeps and the lights are on across the panel but wont start
I have the same problem. Tech guy says it's the electronic panel, doen't have one and it will be 10 days to get it and $370.00 to fix?
Anyone have a service manual?
Mar 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer is spinning, but there is no heat. How do I
The Duet manual referenced below will help you with diagnostics.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/479b6231e5693a13852571650061e709/$FILE/8178559.pdf
Jan 17, 2010 | Whirlpool Dryers
I have a whirlpool duet gas dryer. how do I open
1. Unplug the unit while servicing inside.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 26, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
109 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
