Question about Krups FME2 Coffee Maker
Need to fill resivoir how much
Coffee pot was leaking water from bottom all over counrtwe now I have to fill resivoir and I have no clue how much water to put in back
    Problem Solver:
  • 17 Answers
Unplug coffee pot, empty over sink, turn on to ensure it has pumped all water out, turn off, refill with water, restart normally.
Posted on Sep 05, 2009
Hamilton beach brew station leaks water all over when filling the coffee maker - no problem once the coffee is brewed...why is the water leaking???
chances are, you're filling the machine up with too much water. look at the water resivoir and see if there's a hole somewhere toward the top or a marking indicating the water limit.
-Bam-
Grape Jelly
May 06, 2011 | Hamilton Beach BrewStation 47214 Coffee...
Water leaks from bottom of unit when making a pot of coffee
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
May 06, 2010 | Waring Pro® WC1000
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
MACHINE LEAKS WATER
Turn on machine w/o water or google the company
Jun 02, 2017 | Waring Pro WC1000 Coffee Maker
Water leak on a Bunn coffee maker model B8W, leak only when brewing a pot of coffee
Where is the leak coming from? If it is from the back of the unit or the bottom then it is cracked and you will just need to replace the coffee maker. If it is leaking from the top then it is a seal issue in the water valve that brings the water from the tank and into the coffe filter and into the pot.
Apr 26, 2009 | Refrigerators
Leaks while filling
Mine just leaked and it turned out to be one of the rubber tubes from the reservoir to the heating element under the pot came off. I removed the 4+2 screws of the base plate, reinstalled the tube & since there are no clamps holding on the tubing, I used thin stainless wire double wrapped and snugged to ensure the tubing stays on this time. Note, there is wiring in the area. Make sure you do not short out any of the electronics with the wire if you chose to use it.
Sep 26, 2008 | Mr. Coffee FTX49 12-Cup Coffee Maker
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Krups FME2 Coffee Maker Logo
194 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
