Question about General Electric A730 Digital Camera
Camera locked says write protect on screen. don't know how to remove this or what it means. Can't take any pics.
    Brigadier General:
  • 11,967 Answers
Is the slide switch on your card in the locked position?
Posted on Sep 05, 2009
"memory card is write protected " on the screen. How to remove it.
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 26, 2014 | Nikon COOLPIX Cameras
Write protect or to unlock pic to delete them
Remove the card from the camera and look for the lock tab. On the image below, it is a yello tab located near the top of the left edge on the long side. This one is shown in the unlocked position. Yours is likely down - at the locked position. Simply push it up and reinsert into your camera and take pictures.
I hope this helps & good luck!
Oct 05, 2012 | Olympus T-100 Digital Camera (Blue), 12...
I just turned my camera on and on the screen it says Write Protect. WHat does that mean?
It means the memory card inside it has been set to write protect so that images cannot be lost. If you take the card out there should be a tiny slide switch on the card itself (usually on the side). If you move the switch to the opposite direction you should be able to write to the card. You might want to check what is on the card before formatting to make sure there's nothing you need to keep :)
Nov 15, 2011 | GE X5 Digital Camera
How do I remove the protected card?? I don't know what I hit??
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 19, 2011 | Fuji FinePix J10 Digital Camera
I cannot delete a picture as the screen says file protected. How do I remove?
if you cant delete any pictures then your sd card is locked which means you take it out and slide the little movable plastic,
if its one pic then you must unlock it in the properties menu
Jul 28, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
My samsung camera wont let me take pics or videos b/c it says "CARD LOCKED" everytime i try to take pics
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Apr 02, 2010 | Samsung L210 Digital Camera
I have the polaroid i830..cameras locked i think
Remove the memory card from the camera (it is next to the batteries). On the side of the card is a little switch, set this to unlocked. You will then be able to write to the card again.
May 12, 2009 | Polaroid i830 Digital Camera
On the front screen card locked comes up when I try to take a pic
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 03, 2009 | Samsung Digimax S800 Digital Camera
What does write protect mean?
"Write Protect" means that something is locked and your device (camera) cannot "write" to it's storage area.
What type of "storage media" are you using?
For example:  the camera's internal memory, a CompactFlash card, a Memory Stick, an "xD-Picture Card" (micro, mini or regular sized), or a Secure Digital/MultiMediaCard.
[Did you put something  (a small plastic card of some sort) into a slot on the camera before or after turning it on?
Those little cards usually have a tiny button (also called a switch or lever) on them that will move back and forth to lock (write protect) or unlock it. This sounds like the memory card inside your camera is locked or "Write Protected.
To fix this simply take it out, closely examine the memory for the button- the button will be closer to the word "lock" or "protect" and all you need to do is gently slide it in the opposite direction from where it currently is. Put it back into the camera and see if it still says "Write Protect."
Let me know...
Rae
Nov 27, 2008 | GE A730 Digital Camera
Accessing pics from memory stick
This is a computer error. Check images are there in the camera by looking at the review screen. Then check you have not 'locked' the stick or 'protected' images turn off the protected then try
Aug 14, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
General Electric A730 Digital Camera Logo
27 people viewed this question
Top General Cameras Experts
JOHN ALBURY
JOHN ALBURY
Are you a General Camera Expert? Answer questions, earn points and help others
