Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Control panel stuck. not able to change any
Control panel stuck. not able to change any settings (i.e. temperature)
  • 864 Answers
Unplug the refrigerator from the power socket for 30 seconds. When you plug it back in the control panel should reset showing all 8s for several seconds and then return to normal settings. If that does not solve the problem then the controller board probably needs to be replaced. As part of the settlement with Energy Star, LG is supposed to be replacing controller boards for free so your problem could be solved by that if you qualify. See http://www.energy.gov/news/6743.htm. Use phone number to contact LG as the web site did not work three times when I tried to register through it.
Posted on Sep 18, 2009
My 2001 buick century blows warm air on drivers side and cold air on passenger side could the problem be that the flapper is stuck.
The electric control actuator more then likely ! Do you hear any clicking come from behind the instrument panel . These actuators have plastic gears inside and they break , strip etc... Can also set DTC'S - diagnostic trouble codes to set in the HVAC - control panel (module ) A scan tool used to check engine codes can't read these codes . Need a factory scan tool or professional grade .
DTC B0361
The HVAC control module receives a left air temperature actuator position signal from the left air temperature actuator. The left air temperature actuator position sensor is a potentiometer that is tied to a 5 volt reference source. The variable output from the potentiometer feeds back a position signal to a pull-up resistor located in the HVAC control module. This signal is used to determine the necessary drive signal to the left air temperature actuator motor to provide the proper air mix door position. This value is stored in the Keep Alive Memory (KAM) portion of the HVAC control module.
DTC B0363
Left air temperature actuator signal circuit stays at 4.5 volts or higher.
Temperature Valve Actuator Replacement - Left Side
Remove the left instrument panel insulator. Refer to Instrument Panel Insulator Replacement in Instrument Panel, Gauges and Console.
Remove the knee bolster. Refer to Knee Bolster Replacement in Instrument Panel, Gauges and Console
Disconnect the electrical connector from the left air temperature actuator.
Remove the mounting screws from the left air temperature actuator.
Remove the left air temperature actuator.
May 23, 2017 | Buick Cars & Trucks
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Where is the temperature control panel of my GSS25JETA WW
It is likely there is no actual control panel, but rather a simple dial somewhere located towards the back of the inside the refrigerator compartment that has lettering that states, "warmer/cooler" with arrows that show which direction to turn to change the temperature setting.
Jul 04, 2014 | General Electric GSS25JET Side by Side...
Mercedes-Bnez W221 4-zone HVAC heat stuck left-rear passenger
you really need help from a dealer tech if you cant read it in your own question, i would point out that dealer test equipment is most reliable, and use of service bulletins to find whats the latest fix for this kind of issue on this make and model. you are asking to research and find what he fixes daily. please consult them to get answer if you can.. if they are not available where you are there is always benz world and pelican. some technicians frequent those sites and answer what they can.
Apr 12, 2014 | Mercedes-Benz S-Class Cars & Trucks
Stuck on ff setting
Hello Ailla, thank you for allowing me to assist you!
Could the error code possibly be "OFF"? If so, there is a possibility that the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Best regards!
Oct 22, 2013 | Frigidaire FKFH21F7HW Freezer
Cannot get temperature buttons on hot tub to change
Do the other buttons work? Is the control panel locked, some spas have a control panel lock to prevent kids from playing with the temperature. Are any of the buttons stuck in the de-pressed/down position? If neither the problem is likely in your topside control which means it will need to be replaced.
Sep 18, 2012 | Pool & Spa
My a/c unit increased the temperature to 88F and will not allow me to change this temperature. It changed to this temperature on its own while it was in use. I have tried turning it on and off. Unplugging...
Good day,,,one thing i could say is that the thermostat / temperature control is not in good condition, althought it can produce one cool setting only, that's why it is always on 88 degs. permanently...you can ask your dealer for the covered life and maintenance warranrtty in order to solve that problem.
Jun 08, 2011 | Fedders Heating & Cooling
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Temperature control panel beeping
There are 3 models with this model #,so not sure if your has lock.
If it does and still changes,contact ge and tell them what is happening,maybe they will send you out a new control panel,if the warranty expired,depends.But it doesn't hurt to try.
This feature allows you to lock the controls
so the settings cannot be changed.
To lock the controls:
Set the controls to the desired settings.
Press and hold the lock pad for
3 seconds.
When the controls are locked, the indicator
light will come on and the control settings
will not be displayed.
To unlock the controls:
Press and hold the lock pad for 3 seconds.
After unlocking the controls, the settings
will be displayed, the lock indicator light
will go out and the settings can be changed.
Apr 14, 2009 | GE PTS22LBN Top Freezer Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
1,180 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
