Question about Sharp (CLMPF0053DE03) Projector Lamp for XV-C10U, XV-100
The service light is blinking ornge - Sharp (CLMPF0053DE03) Projector Lamp for XV-C10U, XV-100
  • 13 more comments
  • jasond1981 Sep 05, 2009
    the lamp service lamp light is blinking orange. the filters were dirty and we are cleaning them. we also bought a new bulb. this unit was boutght this way it has been unpluged for about 2 years. the fans come on but then the lamp service light starts blinking. we also have not pluged anything into it yet
    I have replaced the lamp light bulb. i do not have the manual
    i have replaced the light but the orange service light is still blinking i do not have the manual
    this is not a car its a sharp xv100 projector.
    this is not a car its a projector plz help
    sharp xv100 lamp service light blinking orange
    have replaced bulb what else should we do
    this is a xv100 not a xvz10000 there is no screen so how would i know if i am reseting it or not
    were is the lamp counter on the xv100 the instructions you gave me dose not work because i do not have those keys or a screen on the unit. are you sure you know its not the xvz100000 its NOT the xvz10000 its the xv100 it was made in 1981
    i have a sharp 1981 xv100 projector the lamp service light is blinking orange. we replaced the light but it is still blinking it has been unplugged for several hours and still the same when plugged back in
  • jasond1981 Sep 06, 2009
    yes we have done that and it is still blinking orange
    the unit has not been turned on for like a year so it should not be over heating
    it has been off for an hour now from the last try and it is still blinking
    i have changed the light and taken out the filter and cleaned it
    THERE IS NO ENETER OR SCREEN ON THIS UNIT
    I KEEP GETTING THIS ANSWER BUT I DO NOT HAVE THESE BUTTENS ON MY UNIT
    I HAVE A 1989 SV100 SHARP
    thank you but this is NOT an xvz10000
    its a xv100
    the first lcd projector sharp made as far as i know it is much bigger then the one that everyone keeps sending me info for
    i know i have to restet the lamp thing but i do not know how
    it dose not have a screen it dose not have a enter button
    i have been told to reset it and let it cool down 12 times it has not been on for more then 2 min in over 2 years. so its not over heated. i have cleaned the filters on the bottom. i have replaced the bulb. i do not know oh to reset the lamp counter. i cant hold the enter butten as i do not have one on the unit.
    plz help
    i have a xv100 1989 sharp projector
    it dose not have a screen or a enter button. i have cleaned out the screen filter on the bottom and it has been unplugged and cooled down for 12 hours . i have replaced the bulb. i do not know how to reset the counter and all the info i have gotten so far is for the xvz10000 not the xv100 i DO NOT have a screen or a enter butten
    the orange light is blinking and the unit is
    completely level
    i have changed the bulb
    it is a xv100 sharp from 1989
    it has no screen or enter button
    everyone tells me i have to reset the lamp counter but i have not been told how. all i get is how to reset the lamp counter on the xvz1000 witch mine is NOT. i have the xv100. ff
    i also do not have a screen to do a set up
    did you mean the picture that the unit will produced when i get the unit to work?
  • jasond1981 Sep 07, 2009
    i do not have an enter butten
    President:
  • 1,723 Answers
The dust cover lid is open or the dust filter needs to be replaced.
Posted on Sep 07, 2009
    Brigadier General:
  • 5,158 Answers
Try this please
hold down while it is off "down" "right" "Enter" and "on" at the same time. I don't know if this will help but that is the oldest sharp I have to offer information on.
    President:
  • 1,197 Answers
Orange blinks indicator
After turning on the projector, the Setup Guide screen appears to assist you with projector setup. Adjust the projector by following the illuminated buttons or Setup Guide indicators. Press TENTER to turn off the Setup Guide screen. Guidance items 1 FOCUS 2 HEIGHT ADJUST 3 ZOOM
You can adjust the focus with the focus ring on the projector. Image Projection Rotate the focus ring to adjust the focus while watching the projected image.
The height of the projector can be adjusted using the adjustment feet at the front and rear of the projector. When the screen is in a higher position than the projector, the projection image can be made higher by adjusting the projector. 1 2 3 • Do not apply too much pressure on the projector when the front adjustment foot comes out. • When lowering the projector, be careful not to get your fingers caught in the area between the adjustment foot and the projector. Use the rear adjustment foot to make the projector level. • The projector is adjustable ±1 degree from the standard position. Remove your hands from the HEIGHT ADJUST button of the projector after its height has been finely adjusted. • The angle of projection is adjustable up to 7.5 degrees from the surface on which the projector is placed. Lift the projector to adjust its height while pressing the HEIGHT ADJUST button.
at any point during the adjustment the orange blink shud stop.... if not... its better to call a service tech
regards iversh
Posted on Sep 06, 2009
  • 426 Answers
Have you tried changing the air filter on the bottom and allowing the unit to cool off, sometimes they overheat and this is what is causing the malfunction.
  • 3,741 Answers
You will need to replace the lamp in the projector.the orange is blinking because the lamp of the projector needs replacement.if you have replaced the lamp and its still blinking orange.then the lamp needs to be resetted. procedure to reset is RESETTING THE LAMP HOUR COUNTER The unit is designed prevent the lamp from lighting when the lamp counter has been used for 1900 to 2000 hours. This is to protect the lamp module. When this occurs, replace the lamp module with a new one and use the following procedure to reset the counter. RESETTING THE LAMP HOUR COUNTER 1. Turn the Master Power off using the red button located near the AC input jack. 2. Hold down the “ENTER”, “ADJ(lower arrow)” and “ADJ(forward arrow)” buttons simultaneously on the projector. While keeping them depressed, turn on the Master Power with the switch near the AC input jack. (See diagram below) 3. The unit should power up when you do this and the lamp should light. Look for “000H” to be displayed on the screen, which will confirm you have reset the counter to zero. Note: It is possible that you may have to perform these steps 4 or 5 times before it works correctly. Also, on some models, you may have to continue to hold the buttons and press the Power button on the front of the unit after turning on the Master Power. Note 2: Be sure to orient yourself correctly when working performing this on a ceiling mounted projector – it is easy to confuse which buttons are “down” and “right” in this case. this will help. ----- thanks.please do rate the solution.thank you for using fixya.keep updated.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. After replacing the Lamp you'll need reset the Lamp counter. You can reset the lamp counter by following the procedure.
Sharp projector Lamp Counter reset--
Plug the projector in. Do not turn it on.
Hold the menu, press enter and down keys at the same time....
Press On, the map will turn on and the screen should display Lamp 0000H.
For more details you can get the manual from this link--
Sharp Projector XV Series Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 05, 2009
  • Rylee Smith
    Rylee Smith Sep 05, 2009
    Did you try to reset the lamp counter? If yes then let it remain off for 4-24hrs so that it can cool down and reset itself.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Sep 06, 2009
    Hi
    Thanks
    Rylee
    President:
  • 2,004 Answers
Simply indicates that there are multiple error codes resident on the car computer.
Consider running a diagnostic scan on the car for the error codes to be revealed.
Resources at http://www.troublecodes.net/OBD2/
Rate this please.
  • Sharp Master
  • 19,396 Answers
The projector is on protect mode because an internal fault had been detected.
Try first leaving the power cord unplugged for one or two hours.
If that does not work there is an internal fault.
If the lamp light is not on, common faults can concern PSU board, ballast board and controller board.
Parts are available here.
  • Ginko
    Ginko Sep 05, 2009
    If the lamp light is blinking, then you need to replace the lamp.
    Try first replacing the lamp and see if this can get rid of the problem. If it does not it is often the lamp power board, that can trigger the same lamp service light.
    The owners manual has detailed instructions with pictures explaining how to replace the lamp.
My hp dv5 laptop started flashing caps lock light , f12 ornge light is on
what OS, what DV5 it has a full model, DV5 is huge family of PC.
like DV6-1235us. that is fake but you get the idea.
the flashes are called error codes.
what is the code. it tells you whats wrong.
hp has like 1billion folks asking this since 1982
read one? best is to ask them and tell the real model number.
codes vary BY YEARS made.
https://h30434.www3.hp.com/t5/Notebook-Boot-and-Lockup/HP-Laptop-Error-Blink-Codes/m-p/6142972/highlight/true#M114096
Jun 02, 2017 | HP Computers & Internet
Problem with Sony FD Trinitron WEGA KV-32HS510 32" TV
Blinking of standby LEDs to Sony TVs are fault indications. Form the number of blinks occur at one time, the repairman can get an idea of the faulty stage inside it. According to you, it blinks 4,6 & 7. Just visit this site, It has details about blinking codes to Sony TVs, both CRT based, Flat panels and Plasmas. I can't provide more advice to you, because the number of blinks are not constant. Check the site, and get it.
Jan 22, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
How to remove vodafone services from nokia c5
You can get the unlock code from your service provider or from any online sites and unlock your Nokia C5 from its network. Prounlocking.com is where i unlocked my phone , they offered codes at affordable price with simple unlocking instructions. After unlocking your phone you can use it with any GSM network!!
Aug 13, 2012 | Nokia Lands Phones
My envision lcd l37w698 wont turn on and it has a ornge light that steady blinks
DEAR user,
its supply capacitor may be weak so that's why its not turning on.
Feb 08, 2011 | Televison & Video
Blinking ornge light
reset your printer if you try you can i will give you 6 tips
Here this manual way step by step to resetting waste ink counter on printer canon iP4000.
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. Do not release the buttons. The LED light should be green to indicate that a function is selectable.
  2. While holding the Power button, release the Resume/Cancel button, do not release the Power button
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  4. When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  5. Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  6. Press the power button to exit service mode.
see you can where is blinking orange light
Sep 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer is not working just orng lites r blinking
This could mean paper jam or low ink in one of the cartridges.
Hope this helps!
Feb 06, 2010 | Epson STYLUS R230 InkJet Photo Printer
IPOD Frozen, dead. Unable to light on (grn or ornge). No connect.
Aug 07, 2009 - OK, I found the answer...there was a problem with the updated Windows service pack. I had to uninstall all applications(even in recycle bin) of all previous service packs including the new service pack 3. Then, went to Windows update and reinstalled the service pack 3 only and after installation, my ipod came to life! It was beautiful....Must be a compliant problem with the packs...I don't know!
See less
Dec 30, 2008 | Apple iPod shuffle MP3 Player
81 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
