Turntable drags. This is an old jvc, probably 16 years or so. Still works, but afraid the belt is stretched. Can we get replacement. Is this a dyi job? We are fairly handy. Betsy
  • bbuehrig Sep 06, 2009
    Very helpful, however this platter is locked down. Has two key slots, but we have no key and the platter is locked down, solid. So...thanks for the belt info, very helpful, will check RadioShack. Thanks
    Will keep trying to remove platter. BEtsy
  • 189 Answers
HELLO BETSY!
It's pretty easy to change a belt on a turntable. Lift off the rubber mat and platter (the round part that turns) and you will see the motor on the deck. The platter has a rim underneath where the belt goes.
The platter should have some holes in the top of it and this will help you to put the belt on to the motor pulley.
First, put the belt on the rim of the platter. Hold the belt tightly through the hole in the platter and put it onto the centre spindle. Locate where the motor is and put the belt around the pulley - DONE!
As for getting a belt any good hifi dealer/service centre or Radio Shack outlet should be able to help you - it is after all - only a rubber belt! (:-)
Posted on Sep 06, 2009
Testimonial: "Thanks for the quick response. "
  • Tony A Sep 06, 2009
    HELLO BETSY
    Have not come across that before regarding the platter - must be an odd one!
Turntable not rotating. What should I do?
HI, lift the platter off and check belt. If it is broken or stretched you will need to replace it. To test belt for over stretch simply place it on the platter pulley then flip platter over the right way up. If belt stays put it is ok, if it falls off it needs replacing. Keep em spinnin, John Stylus City.
Jun 20, 2014 | JVC AL A158BK Turntable
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
I have a 30 year old JVC L A120 turntable. When I pulled it out of my closet, I found the belt had broken and decided to buy a replacement. Before installing the belt, the motor spun and couldn't be...
Clearly a fault with either the motor or the power supply side of it. Try turning the motor spindle with your hands. If you can't get it to move or it's very hard to move, replace the motor.
Aug 25, 2013 | Audio Players & Recorders
How do I change a drive belt on my JVC L-A11 Turntable
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Dec 15, 2009 | JVC AL A158BK Turntable
Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
May 03, 2008 | Technics SL-1210 Turntable
JVC turntable LA10
The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
Hope that helps.
Mar 16, 2008 | Audio Players & Recorders
Table turns only once in a while.
The problem is probably the belt. When a belt gets old it tends to stretch and/or get stiff. Listen to see if you hear the motor turning. If it comes on when you lift the arm, it is not the switch.
Jan 27, 2008 | JVC AL A158BK Turntable
How to replace belt in jvc turntable
I just got a JVC turntable from a thrift shop today and as soon as I got it home the belt broke. I had a replacement but couldn't figure out how to install it. After taking off the back, which is about 4 screws plus the 4 feet and the grounding screw, I saw a very tiny set screw on the post where the spindle obviously is. I removed this and the table came right off so I could replace the belt. I couldn't get the tiny set screw back but figured I didn't need it and if I ever have to replace another belt, I won't have to take the back off anyway. I hope this helps.
Jan 02, 2008 | Audio Players & Recorders
132 people viewed this question
 Grubhead
Grubhead
