Question about Refrigerators
I have a model # HTS22GBMBRCC Hoypoint Refrigerator. the fan in the back runs all the time and I the fan inside the freezer is running all the time. Neather the Freezer or the frig is getting cold. I have read about defrost timers for other models but can find one for this model.I need help fixing this.
  • Refrigerators Master
  • 1,606 Answers
Your model has no defrost timer . It works off a main control board . If there is frost on the rear panel inside the freezer , then you have a defrost problem . This would be another paragraph ( but let us know if there is frost and someone will be glad to help ) . If not any frost , then the compressor may not be running . If the compressor not running , main control board is bad Pt # WR55X10942 . You will have to pull out refrig and remove the panel covering at the bottom to check . The main control board , is behind the 8 " X 10 " panel at the top left , behind the refrig .
Posted on Sep 05, 2009
Testimonial: "I will try it when I get the part in thanks "
Freezer and refrigerator not getting cold but motor running
What is the make and model of your fridge?
Mar 31, 2014 | Refrigerators
Freezer not worknig.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | GE GSS25JFM Side by Side Refrigerator
Fridge not getting cold at all - Hotpoint - HTS22GBMBRCC
Good day,
You don't recharge a sealed system on an appliance such as a refrigerator.
First, you find and repair the leaks if any, or search for restrctions internal to the system, and if the compressor is pumping properly, recharge.
This type of work is limited to a highly skilled tech, with the proper equipment and must be on site to analyze.
Thank you for using FixYa
Jan 04, 2010 | Refrigerators
The panel separating my side by side refrigerator from the freezer is hot - nearly to the point of burning. Kenmore model 10653606202
  1. check if the evaporator fan motor is running (inside the freezer)
  2. Same for the condenser fan motor on the bottom in the back of the fridge
  3. Clean condenser coils underneath or in the back of the fridge
  4. if there is a frost on the back wall in freezer - you've got the defrost problem, check defrost heater, defrost bimetal thermostat, and defrost timer
Oct 14, 2009 | Whirlpool GS6SHAXLS Side by Side...
The door jamb on our Kenmore refrigerator model no. 106.53354300 is hot to the touch. Most items inside the freezer are soft.
The condenser fan underneath the fridge is probably not running. It should be running when the compressor runs. You can place a floor fan back there blowing until you have it replaced.
There is a slight chance you have a defrost system failure causing the coils behind the back cover inside the freezer to ice up blocking air flow. This would also affect the temp in the fridge and freezer though.
Aug 13, 2009 | Refrigerators
Freezer not freezing
when the freezer is not freezing, check the fan and fan motor in the freezer section. It should be running when the compressor is running. Check for frost. If you see frost on the rear inside panel, the frost is usually about 3 in. thick on the inside. Check and make sure the fan next to the compressor is running, if your's has one. It will run when the compressor is running. Check for gaps in your door gasket. If there is no frost, both fans are running, compressor is running, and no gaps, and your coils outside the refrigerator are clean, it doesn't sound good.
May 04, 2009 | GE Hotpoint Top-Freezer Refrigerator
Refrigerator not cooling sufficiently/ Freezer not freezing
Yes, if defrost board is bad it will cause problems. Need to listen for fan inside the freezer compartment also. If freezer does not defrost cold air will not circulate properly causing warmer temperatures inside refrigerator. Is model number SXD524VW ?
Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Kenmore top freezer leaking water on the inside when defrosting
MAKE SURE THE FAN IN REAR OF FREEZER COMPARTMENT IS RUNNING , SOME TIME YOU MUST DEPRESS THE DOOR SWITCH ON THE FREEZER DOOR TO WATCH FAN IF NOT REPLACE FAN , NOT BAD MOST UNPLUG , IF THIS IS NOT IT YOU COULD HAVE A INTERMITTENT DEFROST TIMER OR A BAD DEFROST HEATER
Feb 24, 2009 | Kenmore 18.9 cu. ft. Top Mount...
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
