Question about Ricoh Aficio CL3500N Laser Printer
How do I refill the CL3500 cartridge? I just bought refill from the Amazon but their instruction they label on the bottom doesn't seems like that it's for the CL3500N. Please help if anyone know.
LOW INK MESSAGE AFTER A REFILLED CARTRIDGE
cartridges have chips, you need a cartridge with a special chip that resets each time. These can be bought on ebay or amazon. You cant refill factory cartridges with oem chips.
May 27, 2014 | HP Officejet 6500 AllInOne InkJet Printer
Please help me to refill my ink cartridge, hp has complete instructions for remanufacturing but i could not find for canon. can you help?
There are catridge refill kits available for Canon catridges. Be sure to make sure that the kit will refill the cartridges for your model. Here is a link to a refill kit available on Amazon.com: http://www.amazon.com/Cartridge-Refill-CLI-8B-CLI-8M-CLI-8Y/dp/B00246MOHK
Jan 10, 2010 | Office Equipment & Supplies
I have an Epson stylus nx400 printer. I bought the ink refill kits that were recommended for it, but it's not listed on the instructions. I just want instructions on how to refill my cartridges.
Use syringre with small outlet. Fill from bottom side of ink tank. Better you don't refill ink tank. It will distort rubber seal at bottom side of ink tank. Then ink will leak. After refilling, you must reset ink counter. Do you have chip resetter?
Aug 17, 2009 | Epson Stylus NX400 InkJet Printer
Replacement Cartridges and Reset Button Orange Led
That usually means that the chip on a re-manufactured cartridges had not been reset properly.
Ensure you removed the little cello strip from bottom side of cartridge.
Try unplugging printer power cord for five minutes, and also re-fitting cartridges.
If that does not work call the company and have them replaced.
Note: for the future, it is better buying always original new cartridge rather than refilled/refurbished ones, as you do not know as many times a refilled had been used. On sporadic occasions refilled cartridges can fail and damage the printer.
Apr 11, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Refilled cartridge not printing
Try to cartridge manually ,please follow the instructions :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Feb 17, 2009 | HP DeskJet 825c InkJet Printer
How do i refill an ink cartidge?:
There are five holes in the top of your cartridge. You can get the label off with a razor blade or a heat gun. Then inject the ink through one of the holes and hope you don't get an air bubble in the sponge. Do not allow ink to float on top of the sponge as the cartridge will not work.
Jul 26, 2008 | HP Photosmart 2575 All-In-One Printer,...
Ink cartirdge
If it is a black cartridge then you can put the hole anywhere in the top as it is all one sponge. If it is colour then you need the holes in the following places.
Magenta (Red) - Top Centre.
Cyan (Blue) - Bottom Left.
Yellow - Bottom Right.
If your still unsure it is quite simple to pop the lid off with a normal knife and refill directly into the sponges. When finished you can simply stick the lid back on, although this is not as tidy looking it will work fine.
Good luck.
Please rate my advice, good or bad.
Feb 04, 2008 | Canon PIXMA iP1600 Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
HP 95 Tri color inkjet cartridge refill
Yellow Top
Megenta, Bottom Left
Cyan, Bottom Right
(leave the middle two holes alone)
Jan 05, 2008 | Office Equipment & Supplies
Ricoh Aficio CL3500N Laser Printer Logo
47 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
