Menu button not respondign on a Pure Bug Too
Menu button not responding on a Pure Bug Too radio - the button/switch is fine - its something in the coupling/decoupling to the controller circuitry which isn;t right. Anyone fixed one ? anyone got a manual for one ?
  • Richard Clark Sep 08, 2009
    Clarification
    Hi. No, it's just the menu button that's faulty. I've actually had the unit apart and the buttons all bell out with a mutli meter. There's a bank of surface mount components on the main PCB which buffer the switches into the control set up. The switch position is making it that far into the circuit, but no further. I can;t get hold of schematics so I have no idea what these buffer components are. It used to work, but it;s always been difficult to get the exact response you'd want from the buttons, but for weeks now, the Menu button has been dead. I actually play MP3s from a memroy card and I've taken to setting an alarm to get the basic functions to appear now - there's no other way in without the menu function !!!
  • abrown497 May 11, 2010
    You can download the manual fromhttp://www.pure.com/support/Manuals/VL-6... but it doesn't have anything helpful in there. I have the same/similar problem - the up/down scroll and left/right volume adjust work fine, it's just the menu select push that doesn't - is that what leads you to believe that the switch is fine? I had this problem 6 months or so ago and it went away after a few days but it's ocme back again - so I've no idea what's going on.
I have just heard back from Pure:
"Unfortunately the item cannot be repaired and has now been discontinued."
I have suggested, since there is no other option available to anyone in our position, that they publsih the scematics.
Posted on Sep 09, 2009
One handset is not responding and when pressed for long time the emergency alarm is turned on. Is there any reset button to troubleshoot this...?
remove battery for a few minutes and see if connections are clean- if when batteries are inserted and still have problem--- problem with mother
Jul 10, 2016 | Motorola MJ270R Two Way Radio
Change the Brightness on Toshiba DX735 D3204. The Controls on the monitor do not respond when pressed.
If the remote is anything like a Television one then maybe via Menu or preset button for Picture adjustment i.e. to get to brightness adjustment.
If you find it and are able to control it via Remote than that would tell me that it's not the driver/software problem BUT something between buttons on the monitor and IC controller...BUT I'm curious do any buttons on the monitor work besides? Power on/off? if so then it really could be just a software bug.
either way good luck.
Jan 19, 2015 | Toshiba Computers & Internet
Bauhn ADR-6R
Manually tune to a station and hold a knob until it beeps. Do the same for all presets.
Jun 04, 2014 | Pure Digital The Bug DAB Radio
Reset factory settings of my Denon avr 2800
From Denon support:
To reboot, turn receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory default.
Sep 08, 2013 | Denon AVR-2800 Receiver
Pure DAB radio not coming on when turned on. Just showing setting clock on display?
On all PURE products you have the option of being able to return the product to its original factory settings. As well as being useful for fully re-tuning the radio, a reset effectively 're-boots' the product's operating system which removes any user settings such as presets and timer/alarm settings. A reset can often resolve any anomalies found.
tip.gif Note: You will need to re-enter your network security information after performing a factory reset. Make sure you have your network security key to hand before performing a reset or you will not be able to re-connect your radio to the internet.
Instructions for EVOKE Flow/AVANTI Flow/ Oasis Flow/ ONE Flow: Make sure your radio is switched on. Press and hold the 'Options' button down for two or three seconds and confirm the reset when prompted.
Instructions for Sensia: Make sure your radio is switched on. Tap 'Settings', tap 'Update' and tap 'Factory Reset'. Confirm the reset when prompted.
Instructions for Siesta Flow: Make sure your radio is switched on. Press and hold the 'Options' button down for three or four seconds and confirm by pressing the 'YES' button when prompted.
Dec 29, 2010 | Audio Players & Recorders
I have a Pure One classic radio.When turned on the display screen reads "upgrade (reva) press any key to exit)I press a key but the same screen comes up again.Cannot get any station to play and can...
I have the same problem, and no real solution, although I do find by hitting one of the keys several times in rapid succession, then pressing the standby button, the radio does tend to come on.
Really irritating, though, and I'd love to know how to fix it for good. Good luck - and do let me know if you find a solution.
Gilly
Dec 06, 2010 | Pure Digital The Bug DAB Radio
MY PURE 3 dab RADIO stopped working overnight - it was working perfectly saturday night but was completly dead sunday morning. It has a battery pack attached and i have also tried using another PURE mains...
I have purchased 2 Pure Radios (Mio &Evoke Flow) and have had the eact same problem you mention. It is definately a bug with the radio.
I have had the Mio replaced twice and the Evoke Flow once. 6 months later I had the same problem and took it back and got a credit. I would not trust this brand any longer...
Nov 03, 2010 | Audio Players & Recorders
Switch on Pure Sonus 1xt and display lights up but that is all
Did you find a solution for this as I have the same issue?
Assume not power supply as powers up fine just doesn't become responsive or tune or anything... glowing, blank screen.
Can't do a firmware upgrade either as that needs to be triggered from the radio menu and the menu cannot be accessed!
Chris
Sep 20, 2009 | Audio Players & Recorders
Pure highway signal
could you tell us something about "the set"? more details please.
Jun 08, 2009 | Radio Shack TRC-521 CB Radio
CLS 1110 Programming
Not certain what order you are doing it, so I will type a brief explanation:
With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming.
Mar 23, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
153 people viewed this question
 Grubhead
Grubhead
