Question about All-Pro Forced Air Kerosene Space Heater SPC-K75
Reddy heater - fires up runs 10 sec and shuts down
Is it flame out sensor
shastalaker7
  • 1515 Answers
SOURCE: The heater will run for about 45 sec. and shut down
Hi, make sure the fan is staying on before it shuts off. It sounds as though the unit is shutting off on high limit switch. For what reason I do not no. It could just be faulty. If it is a forced air as you say and the air is not as strong as it normally would be, this would cause the high limit to open. If you have a diagram or a manual on it anywhere, you can try and find this high limit switch and use a piece of electrical wire to bypass it or jump it out to see if this is the fault. They are normally located in the burner section, the probe part of it anyway. It senses the temperature of the out-put and if the fan is forcing enough heat out, and if not, off it will go. So, try and locate it and jump it out. If it continues to run then this is a safety switch and should only be left jumped out while trouble-shooting and must be replaced. If you can't find one in town, you can order one on the Internet. Check the motor also and check to see if all parts where the air flows is clean also. Get back to me and let me know what you have found and if we need to go further into it.
Sincerely,
Shastalaker7
Posted on Jan 19, 2010
  • 77 Answers
SOURCE: will not stay running
first plae to check is the electric eye. it has to tell the control circut that it sees good flame. next check to see that the fuel filter is clean.
Posted on Jan 22, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: fires up and runs for 2 minutes and then cuts out
Replace the primary control (the component that has the reset button).
Posted on Feb 05, 2010
hardrocko
  • 1476 Answers
SOURCE: My electric Kerosene heater will shut off
You need to do a little maintenance. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts to get your unit running like new. Most portable heater parts are the same. Also DESA went into bankruptcy but many dealers still sell parts. It is all in my tip. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Posted on Mar 03, 2010
heatman101
  • 43501 Answers
SOURCE: Heater fires up and runs
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Feb 03, 2011
Runs for 10 to 20 mins. than shuts down
Clean the sensor that insures flame is burning.
Feb 10, 2011 | Reddy Heater 60,000 BTU Kerosene...
Fan comes on glow plug lights up but no flame.3 sec. fan shuts down.Have clean all lines, tips everything. Model 60 Reddy used very little in ten years.
this have a flame controler, if the flame didn't goes on in few seconds the unit automatically stops. back plug and start again, if not star after tree times check the flame control thermocuple, or get the unit in service to fix it.
Feb 14, 2010 | Reddy R60A Utility Heater
170T RUNS 10 SEC SHUTS OFF. NEW FILTERS HAVE BEEN INSTALLED
check the electric eye. sounds like it can't see the flame.
Jan 11, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater won't refire after it warms up
CAD flame sensor is bad, 3$ part and easy to install.
Jan 22, 2009 | Reddy Heating & Cooling
Reddy heater 110btu kerosene starts and shuts off?
I would say the thermostat is bad after reading your problem over several times. There is no reason to suspect a wiring problem, and I strongly suggest you don't bypass anything! A fire or explosion could result. Replace the thermostat as a probable cause.
Ray
Dec 08, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy heater R55tb
what is pictured is a propane heater. two problem areas come to mind. one) the hi limit cutout, and two) the flame sensor. the hi limit is a normally closed device that is bolted to the back plate of the fire chamber. its two wires go to the cappilary of the flame sensor. the flame sensor is of the j-k thermocouple. it generates a millivolt signal to keep the pilot valve open. the flame sensor generates a dc output to the tiny electromagnet inside the main valve. when you start the unit, a hot surface igniter heats up, the main valve opens, a signal is generated to keep the valve open. if it doesn't sense a flame it shuts down and goes into lockout. change the flame sense unit first. what you can also do is temporarily put a jumper wire on the two terminals on the cappillary of the flame sensor.
Nov 29, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
All-Pro Forced Air Kerosene Space Heater SPC-K75 Logo
163 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
