Question about Sewing Machines
What causes a zigzag stitch machine to make straight stitches periodically?
  • 202 Answers
It sounds like your machine is skipping stiches. First thing you should do is put a new needle in. It could be dull or bent. And you need to be sure the needle is in correctly. Usually the flat side to the back. Unless you have an old machine. If the tensions look good then I would say next that your machine is out of time and the hook beneith is only grabbing the loop on one side. Also your needle height may be off.
Hope you get it figured out.
Posted on Sep 05, 2009
My sewing machine only sews zigzag stitches never a straight stitch. Why?
We need to know the make & model machine.
If it is an older mechanical Kenmore, more than likely it is seizing due to old oil turning to glue inside the machine. Unfortunately, these old machines were made too well as the manufacturers never anticipated the machines would be around for 50 years. However, as mechanical machines they do need regular cleaning and oiling with a good quality oil, ie liquid Tri-Flow Synthetic Lube or "good quality" sewing machine oil.
Either the stitch width regulator is broken or stuck or the mechanism that drives the needle bar is stuck. With plenty of time, patience, elbow-grease & Tri-Flow, your sewing machine will probably be sewing like new.
I've used the following method to free up some great old mechanical machines and they operate like new again:
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
Also, be sure to change the needle frequently, ie every 8-16 hours of use. Most sewing issues can be resolved with a new needle.
May 05, 2017 | Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
Can this machine do zigzags?
The Sew Dlite 11401 shown on Amazon here, http://www.amazon.com/DLite-Supreme-Portable-Sewing-Machine/dp/B0006BDG8Q , does not do zigzags. It only does straight stitches. There are similar models that have a stitch width lever. Those do zigzag stitches and straight stitch when in the zero width mode.
I hope this helps.
Aug 25, 2013 | Sew D'Lite 11401 Mechanical Sewing Machine
Straight stitch
Tension knob on any machine will be in the thread path and usually above the needle somewhere, while the stitch width and length knobs are usually on the right side of the machine. I cant identify your model but on any machine straight stitch is usually a length of 2.5 and width of 0, while a zigzag the width will be set somewhere between 2-4 depending on how wide you need it to be. There is usually a stitch selector of some sort too but many machines, providing the width is set to 0, you will get a straight stitch.
May 29, 2013 | Husqvarna Sewing Machines
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
66 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
