Question about Pioneer VSX-1019AHK A/V receiver
Not controlling the power properly - Pioneer VSX-1019AHK A/V receiver
    Problem Solver:
  • 6 Answers
Do you have Kuro Link enabled? The Kuro Link is enabled by default. If you haven't changed this setting, I would advise you to turn Kuro Link off as many users have had problems with the Kuro Link.
Hope this helps. If it doesn't, consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. They will surely help.
Posted on Dec 07, 2009
Dryer will not turn on. Lights blink and the Code "F-01" shows in the display
depending on your model The F-01 error code indicates a primary control board failure . If the error cleared after unplugging it for a while, then the control board could have received a power surge or glitch through the electrical lines. Completely disconnecting the electrical power and then reconnecting it will sometimes reset the board and it will operate properly. If your dryer continues to operate properly, then resetting the control board may have fixed your problem.
If the dryer motor continues to stop, then you may have a bad control board. A wiring problem or drive motor failure could also prevent the dryer from continuing to run properly. A technician is normally needed to diagnose and repair this type of problem.
If the F-01 returns and will not clear, then you will need to replace the control board in the dryer
Nov 25, 2015 | Dryers
Control penal not working
I appreciate your inquiry, friend!
From the information you have provided your control panel is not working on your Electrolux refrigerator. This could be a possible problem with your power cord or control panel. I would suggest checking the household circuit breaker to make sure that it was not shorted or is not in the off position. If your household circuit is working properly then you may need to have a professional technician out to review your refrigerator. The technician will have appropriate tools needed to pinpoint the problem for proper repair. I hope this information is helpful. -Matt
Feb 22, 2015 | Electrolux Refrigerators
Power a air flo controller wont power up
Call Power A up and tell them they have a crappy product and tell them they should have better quality products...
Oct 13, 2012 | powera Cpfa010022 Air Flo Controller For...
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Power windows locks and mirrors
Sounds like the master switch is not plugged in properly, this is the switch in the driver's door.
Jun 07, 2012 | Cars & Trucks
My Sound Space12 powers on but there's no display and no manual or remote functions to operate the discs or the other functions.Can you provide a answer.regards
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
Mar 05, 2011 | Nakamichi SoundSpace 12 System
The Intelitouch wall control operation is intermittent. If the power button is off for a period of time, when powered on the fan doesn't operate properly. I need to push the reverse button, power the unit...
Your control is malfunctioning. If the fan will sometimes operate normally, it is not a problem with the board in the fan. The replacement control is $50~ through Casablanca, but you can find them on ebay for half that cost, or less. Depending on your model of fan you may have the W-32 control, or the W-33. Most likely you have the W-32, but, reply with the model # and I'll let you know which control you have.
Thanks
Nov 15, 2009 | Casablanca Fan Panama II 50" Ceiling
Steering problem
Your car has variable power steering assist control, this is controlled through a processor or computer module, the control system uses sensors and a hydraulic valve to control this, your local dealer has the proper test equip to address this problem.
Oct 17, 2008 | 1997 Cadillac Seville
Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
HI CHECK THESE....
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
THANKS
Sep 12, 2008 | Washing Machines
Pioneer VSX-1019AHK A/V receiver Logo
192 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
