Question about Frigidaire GLRT212ID Top Freezer Refrigerator
I have a glrt2121dw5 and the ice maker does not get any water i hook power to the pump and the pumps work i even change it and the ice maker is working but no water
    Brigadier General:
  • 3,513 Answers
Okie, this would incicate possibly the thru tube is still ice up or the fill valve is bad or the ice maker is not giving voltage to the fill valve. I would start with a bad fill valve if the thru tube is clear.
Thank You for contacting Fixya.com
Posted on Sep 05, 2009
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Manitowoc ice maker
sounds like your dump valve is stuck
Nov 09, 2013 | Kitchen Appliances - Others
Water does not spray on to the cube makers. I have power on the board from LO1 to LO4 and from LO4toone terminal of the spray pump. I don't have power from LO2 to LO4, nor do I get power from one...
You should have two wires to the pump. when checking with volt meter across both terminals you should reed 115 volts if you are not reading 115 volts from one terminal to the other than it is not the pump. your not getting power to the pump. make sure your getting water to sump tray if no water then pump wont run.
Sep 13, 2013 | Scotsman DCE33PA1BC 15in Built-in...
Ice maker not working I hooked up the water line turned on water waited all night and the ice maker has no ice .thereis water in the door and all the connections seem to be right
FIRST...THE LEVER MUST BE IN THE DOWN POSITION, TO MAKE ICE , IF IT HAS A FILTER . IT CAN TAKE TIME TO FILL THE FILTER INNATELY . IS THE WATER ON ? .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | Kenmore Refrigerators
I had a power surge and ever since my ice maker won't fill with water. If I manually pour water in the ice maker, it will dump the ice.
the water pump is burned out.
the power surge most definitely caused this.
locate the water pump and with a multi meter test for power.Replace.
Sep 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker leaks with or with out power on the far right side
The water valve (or solenoid) that only lets the water through from the water supply line when the ice maker calls for it is leaking you have to replace it.
May 02, 2009 | Thetford Norcold RV Cooler/Freezer
Ice maker has stopped working. It was fine 3 days
check water valve or icemaker valve is at the back of the unit
Apr 07, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker not getting water in the line
The only other component stopping the valve from putting water into your icemaker is the icemaker itself. Replace your icemaker and you should solve your problem.
Nov 14, 2007 | Amana ARS2464B Side by Side Refrigerator
Ice Maker Not Making Ice
There is no pump per say.. the water pressure is all that fills the ice maker and provides water to the drinking dispensor. The solenoids are also different, one activates for ice maker and the other for drinking water. The fastest way to check water flow is to swap the wires on the solenoids so the drinking water "power" will now power the ice fill solenoid. Once the plugs are swapped and you press the drinking water lever the ice maker should pour water out the fill tube. If that works then you know the solenoid, tube, etc. are all fine. I'd suspect then that the ice maker fill solenoid isn't getting power when it is suppose to fill. Let me know what this test result is.
Jan 23, 2007 | Samsung RS2534 Side by Side Refrigerator
Frigidaire GLRT212ID Top Freezer Refrigerator Logo
49 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
