Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
RayPak 2100 series digital pool heater Code "EOL".
I have a RayPak 2100 series digital pool heater, Model P-R335A-EN. I turned it on and everything worked fine, the burrner came on and cycled off. I turned the heater off at the switch on the side of the heater. Now I have turned it back on and the digital display reads ''EOL''. The owners manual says it means End of Line (Factory use only). What can I do to make it operational?
  • 366 Answers
Press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Posted on Sep 16, 2009
ROL keep displaying on my raypak rp 2100
check gas pressure if too low it will overheat replace rollout fusible link if it happens again you might need a vent stack
Jun 23, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool heater will not work
Eol is a manufacturers code meaning End Of The Line. I have never seen this displayed on any malfunctioning heater that I've serviced. Try shutting down the power to unit and resetting the board.
Apr 09, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 digital heater give fault code eol
ILO or ROL. There is no EOL.
ROL is a switch inside the lower left corner of the heater. Press the red button. ILO is a lockout. Power down and power up.
Nov 22, 2008 | Raypak Pool & Spa
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
1,273 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
