Question about Oase BioTec 10.1 Filter
My pump keeps triping the electrics off
My water pump keeps tripping the electrics off
  • 548 Answers
If this is a new installation you may have too much load on one circuit, if it is an old installation check to see if something else has been added to the old circuit.ie: microwave lights applaince etc, if this isnt the case you have a short somewhere in the water pump and it is causing the load to trup your breaker have the pump checked
Posted on Sep 05, 2009
Keep triping out when pressing spray switch
Any electrical device could trip out if in contact with water, potentially dangerous find the leak and you've solved your problem. PBK
Dec 01, 2013 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
Have 3/4 hourse shollow well pump. When I turn more than one thing on such as outside hose and inside faucet, trips the pressure switch on pump, and has to be reset.
The switch you have on the pump with a reset lever is a low water pressure switch that will trip when a load is on the pump like a leak or no water in well and switch will trip to save life of pump. One way to get around this is to install a regular pressure switch and it shouldn't trip out.
Advantage of a low water switch is to save the pump and it constantly triping can be frustrating and I have changed some to put a regular switch in to avoid having to go offen to reset switch.
Aug 02, 2011 | Wayne Water Systems Plumbing
Motor keeps triping in
If the pump is tripping the GFI then could be a broken pressure chamber, which is were all the electrical components are and if it senses water it will trip the GFI. Solution will be to replace pressure chamber complete.
If the pump is turning on by itself then water could be draining back into the pump. Either the flapper inside the toilet tank is leaking water or the check valve on the discharge elbow is not closing all the way. Solution will be to inspect flapper on flush valve (inside toilet tank) or may need to be replaced. Also the flapper on the check valve must be inspected for obstructions of may need to be replaced.
Jul 13, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
The therostat breaker keeps triping no mater what the therostat setting is. I have to reset the breaker each time i want hot water. Is this GE solution to save energy?
It sounds like the thremostat may be shorting out they are not to exspensive to replace.
It it constantly triping there is a wire touching somewhere.
May 16, 2010 | General Electric GE SmartWater Household...
Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
The wt714g keeps tripping the electrics off, have checked and cleaned filter but still doing it
if it keep triping the power supply at the mains box there is a serous short in the washer, get it looked at fast before it bites you, if the trip ever fales the washer will become the killer in your kitchen
Oct 18, 2009 | Washing Machines
Aquascape 4500 pump trips breaker when plugged in
water getting into pump.Thats what is triping it.
Jul 31, 2009 | RTO AquaScape 4500 GPH Pump
My hotpoint ultima keeps triping the trip switch. it had f08 on the screen but now that has gone, but still trips electrics every time i press start.
Hi
f08 means heater relay cannot be actived so try unplugging heater element and see if it stops tripping the electrics.
regards
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Proline W1000 washing machine keeps on triping main electrical switch
check for water leaks,unplug heating element,and try again.or the motor,then try again.
Mar 28, 2008 | Beko 24 in. D3421F Free-standing...
Oase BioTec 10.1 Filter Logo
333 people viewed this question
Top Oase Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Oase Pool and Spa Expert? Answer questions, earn points and help others
