Question about Kenmore Washing Machines
Washing machine bounces on spin cycle,even unloaded
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
Samsungj1045 washes but won't spin out past 7
Try this, unload the washer and put it into spin manually. If it spins for the whole cycle then it is your motor over heating, with the load.
May 07, 2011 | Samsung Washing Machines
Violently spins during spin cycle (even unloaded). Amana top load model NAV2335aww.
Is it unbalanced spin and noisy? If it is, then you bearings are out. If just unbalanced check your base and washer support inside machine.
Dec 15, 2010 | Washing Machines
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Excessive vibrating and banging in the spin cycle with some washes. The unit is only 1 month old. Any advice?
You have a improper installation. The machine has to be perfectly level side to side and frotnt to back. After leveling, check the feet on the bottom and see if one is bouncing on spin with a load. Adjust the bouncing foot down until machine stops bouncing.
Jan 25, 2010 | GE Profile WPRE6100G Top Load Washer
I have a top loading Kenmore Washing machine, Model 110, Heavy Duty, dual action. The machine is level but during the spin/unload cycle, the machine bounces around and makes noise. If I put two cases of...
There are pads on the tripod and skid plate that wear out and can be replaced. There is fluid in the tub ring that may have leaked out. The base (tripod) can be bent and cause vibration problems. The flooring material and support can cause this also. I would start with the floor and work up through and eliminate the causes to find the culprit.
Eric
Nov 19, 2009 | Kenmore 24032\24036 Top Load Washer
Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Maytag washer will not spin, clutch slipping
Sound like it's time to go shopping, sorry
Jun 20, 2009 | Washing Machines
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Got a 4 year old zanussi washing machine and its developed a fault where when it gets to the spin part of the program it just sits there and does nothing,read the manual about unbalanced loading but even...
check wether it does the same thing unloaded if not then its likely to be carbon brushes ,,, presuming it is tumbling durin the wash/ rinse cycles also check front filter zanussi wms will not spin if they cannot clear all water in the drum
Jun 19, 2008 | Washing Machines
Washing Machines Logo
26 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
