Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
My Kodak ESP-3 printer has software that came with it and up until yesterday, I have had no problems. But now when I use the Kodak AiO Center it has an error that reads, "experienced an exception and cannot continue" Error Code 1-2010
Am I correct in thinking Kodak ESP 3 AIO is not compatible with Windows 7 XP x64? I can print and copy but cannot scan either directly from the button on the printer button or via Kodak Home Center
Hi There,
If you've installed the software at the link below already...
http://support.en.kodak.com/app/answers/list/p/5/session/L3RpbWUvMTMwMTM1NjI3NC9zaWQveldEWnY1cWs%3D%2Fselected%2Ftrue/selected/true#s=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..
then the answer would be yes. If you haven't install the software and see how things go.
Regards,
Selk
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
The disk to install my Kodak ESP 3 is broken. How can I install it without one?
You can get the latest software for your machine, direct from Kodak here.
Just enter your model and search.
Mar 12, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak software removal problem
Sure, its very simple. You log onto www.kodak.com/go/clear and follow the online prompts to run the clear tool.
May 04, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Kodak ESP 3 AiO printer. I try to scan my picture but a window on my computer keeps coming up saying ''An error has occurred during import. Either the source is unavailable or the destination is...
It seems that theres a problem on the software of you printer (home center) or on the driver of the printer You need to call kodak toll free 1 800 421 6699., ext 05
Nov 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3 all in one printer home center wont work
hello,
Run the clear utility. Go to www.kodak.com/go/clear
Step by step instructions are provided in that website.
after that uninstall the AIO Home center.
In the Control Panel, select Add or Remove Programs (WINDOWS XP OS) or Program and Features (WINDOWS VISTA OS).
Choose KODAK All-in-One Printer Software
Click Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA
OS).
When the Install Wizard appears, click Next.
Select Remove from the drop-down menu for the Kodak All in One Printer, then click Next.
Click Next.
Click Continue.
Thanks
Neerak21
Sep 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
AiO home center wont open up
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on print pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.
Jun 30, 2009 | Kodak ESP 5 Printer
KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak AiO home Center will not open
My son has the same model and issue. I had him go to http://www.kodak.com/global/en/service/downloads/dln_ekn034524.jhtml?pq-path=12667 and get the latest software and firmware update.
Make sure to use the dropdown to select your operating system. The page defaults to XP.
The software is a new version of the AIO home center.
The firmware installer updates the physical printer. Before you run this program be sure to read and understand the instructions.
If both ink cartridges have good levels of ink, and you keep getting the clean the print head issue after updating both the software and the firmware, then call Kodak support. 1-800-421-6699, 7 A.M. to midnight Eastern time, 7 days a week. They will ask you if you put in new cartridges and installed the updates for the firmware and the AiO centre software. Be patient. They will get a solution for you.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
AIO Home Center Problems
i click on the eyecon and this kodax aio home center encountered a problem and needs to close pop ups
May 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
122 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
