Question about Brother P-Touch 85 Thermal Label Printer
When I power on my P-touch PT85, the display shows an assortmant of figures, horizontal and vertical lines and I cannot get rid of it. It doesn't respond to any other key inputs. The batteries are good, I removed and tested them twice to try and reset the device, made sure they're installed correctly. It powers itself off after about five seconds. Also, I always store it without batteries installed to prevent leakage in between uses.
My Dell XPS 9530 has a white vertical line on the display
Fixing this old of a TV would be a waste of money as unless you have the testing gear and expertise you would be guessing. Just buy new and be happy. You could also join a book club and give up watching TV altogether. LOL
Aug 21, 2016 | Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
How do i get rid of the horizontal and vertical lines on a sony prs 600? the unit was never dropped or mishandled. they actaull appeared as i was reading my book on it
Hi mdill9759,
Looks like a problem with the screen itself. Try this to see fi you can get issue resolved, good luck:
1. Hit the "Reset" button at the bottom of the reader
2. Slide the power switch, at this point the screen should blink and show "Opening book"
3. Allow the reader to load and see if the lines still appear on the screen
If the lines are still on the screen, contact Sony to get it repaired.
eBookBoy
http://digialreader.freeforums.org
Jun 12, 2011 | Sony Reader Touch PRS-600
Horizontal white lines across top problems of my television.
This is probably bad/leaky capacitors in the vertical circuit, around the vertical IC, or the power supply that feeds the vertical. Sometimes you can see domed/ bulged caps or what looks like liquid on the circuit board around the leaky ones. The legs on some caps can even corrode to the point the leg is missing. Care must be taken when replacing them because the acid from the caps can eat away foil traces on the circuit board. All acid must be cleaned off board to prevent further corrosion of parts
Sep 01, 2009 | JVC AV-32850 TV
Picture disappears
My Konka LCD model KDL32AT23U Displayed a picture, then vanished, showing different colored vertical lines in horizontal blue bands.Then I could not turn it off with the remote or standby button on the side.Only with the main switch.What's wrong??
This is the same problem posted by kukish on july 26,2008
Jul 26, 2008 | Konka KDL32AT23U 32 in. LCD Television
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
56 V - faint horizontal lines across the display
u can search problem in vertical section may be sum IC component was dry resold them .
Aug 02, 2006 | SAMTRON 55V 15" CRT Monitor
Brother P-Touch 85 Thermal Label Printer Logo
77 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
