Question about Sony KP-65WV600 65" Rear Projection HDTV-Ready Television
Sony kp-65wv600 projection tv error code 7 (light on front flashes 7 times) after picture turns completely red and then cuts off.
4 Suggested Answers
  • 668 Answers
SOURCE: My Sony KP-65WV600 65 in. Rear Projection Tv after
It is not unusual for the CRTs to cause this problem. In this case the Blue CRT. The problem is that you cannot get them anymore. You must send the CRT assembly to Sony for them to rebuild it. Due to the age of the set and the cost of this process, I do not recommend repairing if it is the Blue CRT causing the problem. The only way to be sure is to have a professional check it out.
I hope this helps,
Sky Assoc
Posted on Aug 25, 2009
johnnydiode
  • 647 Answers
SOURCE: Green projection light not alligning
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Note:The convergence/defletion/power board (the one the IC's are on) of this model is on the left hand side (when facing the back of set) also check for blown pico fuses when replacing the convergence IC's The best way to replace the IC's resistors and possibly fuses is to remove the entire board.
Posted on Oct 19, 2009
Kensolutions
  • 455 Answers
SOURCE: Sony kp-65wv600 projection tv error code. My tv
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Posted on Nov 09, 2010
How I change the video input on my kp-65wv600
There are a couple of ways to cycle through the inputs on the KP-65WV600. The front panel TV/Video button will cycle through the inputs. (This is near the bottom of the button cluster between the Volume - and Flash Focus buttons.) On the original remote, you use also use the TV/Video button; it's above the 1 in the number pad section of the remote. For a third party remote, you will need to find the code that will enable a Source or Input button to cycle through the inputs on the TV.
These are shown in the manual which is available from the product support page: https://esupport.sony.com/US/p/model-home.pl?mdl=KP65WV600&template_id=1®ion_id=1&tab=manuals#/manualsTab . (This is the Manuals, Specs, Warranty tab.) The direct link to the manual is currently https://docs.sony.com/release//KP65WV600.PDF . See page 14 (page 15 of the PDF) for the front panel buttons; see page 48 (49 of the PDF) for the remote control buttons.
I hope this helps.
Sep 23, 2016 | Sony KP-65WV600 65" Rear Projection...
Have a Sony KP-65WV600, already replaced d board once, and replaced convergence ic's once also. Now as soon as I turn unit on, turns to red screen and shuts off, video that is, audio works ok, noticed...
Check High voltage Block.After replacing ic's (STK convergence ic's) you need to adjust Black&White scale.Turn ALL screen adjustments to min.Turn TV on and adjust screen slowly for each gun (I would start with Red first ) when you came to point that you see red background with white lines across, at that point G2 is too high (that will cause TV to shut down,don't worry just lowered adjustment and turn tv back on) so adjust to proper voltage and do the same for each gun.After that, adjust focus for each gun (again all controls are on High Voltage Block and HVB is mounted on front of your tv after you take speaker gril out) black box with 6 controls' screen RGB, focus RGB .
You should do that in dark room in order to get perfect Black&White scale,when all guns are adjusted properly you will see grey picture.Make sure 'Color" adjustment on your display is down to 0. Another step is convergence adjustment ,Flash Focus etc.If TV stil shuts off after all, your Red picture tube is short inside,take crt pcb from tube,make sure TV is unpluged from power before that, and turn Tv on .If stays On tube need replacment...good luck)
Aug 22, 2011 | Sony KP-65WV600 65" Rear Projection...
My kp-57/65wv600 flashes SIX TIMES, PAUSED ABOUT 3 SECONDS AND BLINKS SIX TIMES OVER AND OVER! WE PUSH THE POWER BUTTON AND WE CAN HEAR WHEN TURN ON AND OFF, BUT NO IMAGE/PICTURE APPEAR. THANKS!
First off I would check your lamp to make sure it isn't burnt out. Usually the lamp door is on the backside of the TV. On my 2006 SXRD its on the right side of the TV just behind the buttons. Here is a link to a diagnosis page
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Jun 30, 2011 | Sony KP-51HW40 51" Rear Projection...
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
My sony tv Comes on some times but then some times does not
On most of your rear projections you got GUNS and if there out of allignment or overheat you will get this error and it will need to be serviced.
Apr 22, 2009 | Sony KP-61V85 61" Rear Projection...
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony 5 projection tv kp-51ws510 no pic, light flashs 8 times
I have the same model TV and have had that same problem (*8 flashes) The FLYBACK TRANSFORMER on the D circut board is the most likely cause and will need replaced) the part is around $70.00 USD!
Please rate my response
THANK YOU!
Jan 22, 2009 | Sony KP-51WS510 51" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-65WV600 65" Rear Projection HDTV-Ready Television Logo
327 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
