Question about Radio Communications
Motorola gm300 the set transmits ok, but recieves soft
  • koekie Dec 08, 2007
    Small problems amazes small minds, I've tried 5 gm300 faces on this 1 set and the problem is with the set and not the volume adjustment!!!!
  • 119 Answers
You mean a low volume?
if so try to set it higher (can't be difficult)
Posted on Dec 08, 2007
  • 1 more comment
  • Dick van Zalinge Dec 08, 2007
    i've red (if the volume control is a knob) that it may help to push it inwards before turning,
    this because sometimes the knob has been pushed in before
    it's a standard problem that sometimes happens during shipment
    if that doesn't work, here's a tip for replacement of the cknob (if nesicary)
    i think it's better to get it checked out by a pro (like the guy you bought it from)
    i'm sorry, and good luck with your search
My digitech dc-1005 will sinc ok ,but one will talk and recieve one way but not the other way, has anyone ant ideas on what could be wrong with them,im thinking the rx or tx on one of them may be ********.
There are 2 oscillator circuits in each unit- one for transmit and one for recieve. It is likely the recieving section of the one that does not recieve the other is slightly out of tune.
Jan 25, 2012 | Radio Communications
President HR-2510 will not transmit or recieve
Hi Darrel,
Since you didn't say if you have ever used this radio successfully before, I have to assume it is "new to you" and that you have never seen it work or used one like it before. Start with a few basic settings below:
Turn Squelch to minimum.
Set RF Gain (if present) to maximum
Set Mode to AM or FM
Set volume to 1/3 up
Connect to 50 ohm dummy load.
Turn power on. Hopefully you hear static. If not, try SSB or FM. Still nothing? Try connecting to an external speaker.
Chnage back to AM or FM mode. Key mic check & for transmit indicator. If none, change mic or manually short the PTT contacts in the mic or at the radio to see if it can be made to xmit.
If no xmit - insert SWR meter between xmitter and dummy load. Try to xmit on AM or FM again while watching SWR forward power, if none indicated, xmitter is probably defective.
Replacing parts in a xmitter is not recommended. You'll need an FCC license and a fair amount of expensive test equipment to test repairs, set power levels and deviation and perform an alignment to be sure you aren't causing interference on other frequencies and bands.
You'd be better off bringing it to a radio repair shop for repairs and an alignment.
Sep 29, 2009 | Uniden Radio Communications
Connection via DSL works. A laptop attempting wireless does not
Check the ssid settings in your router to make sure it is being broadcast
Jun 07, 2009 | Westell Wirespeed VersaLink...
Midland alan 48 plus transmit scale not moving
Sorted now, soldered a new output transistor into the board and all working.
Dec 11, 2008 | Midland Radio Communications
Transmite does not recieve
check your squelch make sure its not set too high you should adjust it to just where the static fades out no further hope this helps
Aug 19, 2008 | Cobra Radio Communications
Utilizing two microphones
No, when you buy multiple wireless mics you have to select different channels per unit if you want to use them on the same stage.
hope this helps
thanks for your rating
Jan 09, 2008 | AKG (WMS40DIV444US54) Microphone
Neither Radio Transmits or Recieves
Have you checked that both radios are in the same Channel and the same Squelch Code? are the batteries ok? any rust in the battery contacts? Some FRS radios gets a Malfuntion, and the syntom is like that, check this first
Nov 26, 2006 | BellSouth 2231TE (22 Channels) 2-Way Radio
Radio Communications Logo
111 people viewed this question
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
