I HAVE SONY LCD KP-60XBR800 NO RASTER IN TUNER POWER OK MENU OK BUT NO TUNER RASTER. ALL VOLTS IN TUNER OK, LOOKS LIKE SOMETHING IS NOT SWITHING, IM NOT SURE PLEASE HELP. email me at: sergioaguirre0182@hotmail.com thanks
  • 1 more comment
  • sergioaguirr Sep 06, 2009
    in sorry the model number IS KF-60XBR800 NOT KP IM SORRY ANYWAY THE PROBLEM IS THAT I HAVE NO PICTURE IN ANY INPUT COMPONENT OR TUNER ONLY MENU OR OSD WORK I RESET THE TV WITH SERVICE MODE BUT STILL NOTHING ALL VOLTS IN POWER SUPPLY OK AND ARROUND SOME REGULATORS IN SIGNAL PCB WHERE TUNERS ARE. PLEASE HELP ME MY EMAIL IS sergioaguirre0182@hotmail.com thanks.
    i have a sony lcd. kf-60xbr800 no picture in any inputs component or tuner onlly menu on display i reset the tv w/ service mode but nothing. all volts in power supply ok all volts in tuner ok please help sergioaguirre0182@hotmail.com thanks
    THE model is kf-60xbr800 not KP im sorry but the probleM is that i got no picture in any input tuner or component. all volts in power supply ok. i press menu you see the menu. but no picture in any inputi i allready RESET the tv w/ service mode and nothing i dont have the service manual . please help thanks email sergioaguirre0182@hotmail.com thanks
  • 3,741 Answers
Did to replaced the lamp and checked.if still the same problem the anpother two majpr possibilities are 1)ballast is faulty or 2)colour wheel needs replacement. but this two possibilities can only be checked after bulb is replaced. so if bulb gets power ballast is ok.if no power to bulb ballast is faulty.if bulb glows weak then also ballast is faulty. ------------ you can get required parts at www.shopjimmy.com or at www.partstore.com ---------- thanks.keep updated.
Posted on Sep 07, 2009
    President:
  • 2,777 Answers
Not sure what exactly your problem is... I have read your question multiple times here..
Pleas let me know, is the tuner not working on this unit?
Tim
Posted on Sep 06, 2009
  • 585 Answers
Hi, my name is Eric,
tell me any blinking lights?
thanks
Sony lcd tv model LDM 3000 blinks 6 times and no raster or sound
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Apr 17, 2018 | Sony Televison & Video
Sony kp-51ws520 no picture or raster only menu.
Thats almost always caused by a failure in the vertical circuits which shut the CRTs down for protection but the menu and vol displays function fine. The D board will need to be replaced. You can get the D board for your model at www.tvcircuitboards.com
Jul 24, 2011 | Sony KP-51WS520 51" Rear Projection...
I have a sony lcd kf-60xbr800 no picture in any input or raster no picture in component only menu. i reset the set and still no picture. all tuner voltages ok. help sergioaguirre0182@hotmail.com. thanks
(i) Make sure that the power cable from the TV is securely plugged into a functional wall outlet.
(ii) Then, check to see if the TV/Video setting is correct: when watching TV, it's set to TV, and when watching connected equipment, it's set to video 1,2,3, etc.
(iii) Check if the Parental control feature is activated. You can check it using the Parent menu.
(iv) If the LCD projection TV's power is ON, and LAMP indicator is flashing red then the lamp for the light source burns out. Replace the lamp with new Sony XL-2000U replacement lamp.
(v) If the LCD projection TV doesn't turn ON and a red light keeps flashing then the TV needs service.
Sep 08, 2009 | Televison & Video
Sony lcd kp60xbr800 no raster in tuner all voltages ok. in tuner power ok, menu ok, but no raster please help sergioaguirre0182@hotmail.com thanks
You have a lamp driver error that can be and most likely is faulty and has to be replaced,Also i would not recommend you putting a bigger lamp unless the part numbers are the same to the lamp you are replacing.Moreover most of sony's error codes are the same from crt to lamp tv set like your lcd model tv set, the same concept was used to built your lcd tv set just with different features.
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
With sound but no video only raster with vertical lines
The resistor (r9335) on the blue crt base board is open and burned thats why the 200v is missing. replacing the resistor will solve the problem. cheers!
Apr 08, 2009 | Sony KP-FX532M91 TV
Sony KP-65WV700 DVI-HDTV Issue
Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
From here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Nov 12, 2008 | Sony KP-57WV600 57" Rear Projection...
Snowy Raster on display
Hi mcuyg,
Hope this will give you hint in solving this problem. Try configuring monitor settings in OSD mode; contrast; brightness; etc.. other special settings can be accessed using combination of buttons to minimize the raster intensity. On hardware side try resoldering cold soldered points and check the SMPS side.
Best regards,
Rosener Guyano
Jan 27, 2008 | Acer AL1716 17" LCD Monitor
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
