Question about RTO Beckett # W1150 WTRFall/Str Pump
Where can I find a replacement impeller shaft for a Beckett 1150 waterfall pump
4 Suggested Answers
  • 990 Answers
SOURCE: shaft seal leaks on sta rite pump?
You need to get to the shaft at the back of the motor to hold it while you use water pump pliers or the like to turn it off. It will unscrew in the regular direction but if it has a set screw to hold it in (You will find this at the center of the impeller) this will be a left hand screw so you will go clockwise to loosen it. This should get the impeller off. If not you will need to put a screwdriver in the side of the impeller and give it a hit to lossen the impeller. Good luck.
Posted on Aug 25, 2009
  • 7 Answers
SOURCE: Where can I find a replacement impeller for a 10
I'll bet you need to buy a new pump.Most pond pumps from Beckett are sealed and the impeller can't be or should not be changed.
Posted on Sep 27, 2009
SOURCE: impeller shaft broke at impeller. moytor started
i have the wsame problem. A new pump will run me 550 I dont think I could replace the impeller shaft
Posted on Nov 13, 2010
How to remove a pressed on impeller
Is it pressed on using a keyway on the impeller shaft or is it simply a pressed interference fit?
Jul 21, 2014 | Beckett Corporation Beckett Professional...
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
customerservice@beckettpumps.com
Good Luck
May 09, 2014 | Beckett Corporation Beckett W3500 7114310...
Beckett waterfall / fountain pump W1800 pops breaker everytime you plug it in, consequently it won't run.
Sounds like there are too many things running on the same breaker. Try unplugging some of the other things on that breaker.
Oct 09, 2012 | RTO Beckett W1800 Waterfall Pump
Cant remove broken impeller
Lift off. You may have to attempt to pry it off with two screwdrivers. Other method is to hold it by the impeller while someone takes a brass punch and a hammer and gently hit the end of the shaft to knock it free. Try to avoid damaging the shaft or you will have to dress the shaft up to get the new impeller on.
Aug 20, 2012 | Beckett Waterfall Pump W5000 4983 gph
How to remove impeller
Pull off. Or pry off with two screwdrivers. Or hold it by the impeller and have someone tap the end of the shaft with a brass punch.
Beckett # W1150 WTRFall/Str Pump: Our pump will run for an hour or so, and then it s...
This same symptom happened to me.Check the impeller, if you can pull it out or it just sloshes around in the well housing, then the impeller lock has come out of it's place. Simply pull off the outer intake grill, then twist off the outlet housing. Now you can see that white notched washer and how it must be seated and aligned. Once seated in place use a small screwdriver to turn and lock it in. Now you will see your impeller shaft is no longer loose.
May 17, 2010 | RTO Beckett # W1150 WTRFall/Str Pump
My waterfall pond pumps keep burning out. The
I found that little giant pump are oiled filled and if it gets hot it frys itself... As for submersible pumps Magnetic drive Beckett Pumps are nice. My Beckett pump has been going for 4 years now it pumps 4800ghp. the cost $269 last I looked.
Oct 14, 2009 | Little Giant Submersible Fountain Pump
Where can I find a replacement impeller for a 10 year old beckett water pump? The only model information I have is "798" stamped on the out side of the casing.
Sep 27, 2009 | RTO Beckett # W1150 WTRFall/Str Pump
RTO Beckett # W1150 WTRFall/Str Pump Logo
108 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
