IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
  • 3,741 Answers
Check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 06, 2009
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: I HAVE SONY LCD KP-60XBR800
Not sure what exactly your problem is... I have read your question multiple times here..
Pleas let me know, is the tuner not working on this unit?
Tim
Sony lcd tv model LDM 3000 blinks 6 times and no raster or sound
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Apr 17, 2018 | Sony Televison & Video
I have a sony kp-41t25 and when i use cable , the screen is like really snowy , but if i hook up a ps2 to the a/v jacks its fine . whats the problem ?
Hello
Your TV may have tuner problem. As AV mode is correct, there is no fault in the video section of your tv. Please check the tightness of the cable connection to your TVs socket also. If it is ok, report it to the cable operator and ask them to measure the power strengh of the cable at your home end. If there is sufficiant power strength, replace the tuner of your TV with similar type and number.
Oct 17, 2010 | Sony KP-41T25 41" TV
I have a sony lcd kf-60xbr800 no picture in any input or raster no picture in component only menu. i reset the set and still no picture. all tuner voltages ok. help sergioaguirre0182@hotmail.com. thanks
(i) Make sure that the power cable from the TV is securely plugged into a functional wall outlet.
(ii) Then, check to see if the TV/Video setting is correct: when watching TV, it's set to TV, and when watching connected equipment, it's set to video 1,2,3, etc.
(iii) Check if the Parental control feature is activated. You can check it using the Parent menu.
(iv) If the LCD projection TV's power is ON, and LAMP indicator is flashing red then the lamp for the light source burns out. Replace the lamp with new Sony XL-2000U replacement lamp.
(v) If the LCD projection TV doesn't turn ON and a red light keeps flashing then the TV needs service.
Sep 08, 2009 | Televison & Video
Sony lcd kp60xbr800 no raster in tuner all voltages ok. in tuner power ok, menu ok, but no raster please help sergioaguirre0182@hotmail.com thanks
You have a lamp driver error that can be and most likely is faulty and has to be replaced,Also i would not recommend you putting a bigger lamp unless the part numbers are the same to the lamp you are replacing.Moreover most of sony's error codes are the same from crt to lamp tv set like your lcd model tv set, the same concept was used to built your lcd tv set just with different features.
Sony KP-65WV700 DVI-HDTV Issue
Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
From here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Nov 12, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-43T90 43 in TV only works with DVD but not with cable or antenna
Connect cable at RF input and please perform Auto Search in TV Menu to search available TV channels transmission and still no signal reception means Tuner is defective in TV.
Sep 04, 2008 | Sony KP-43T90 43" Rear Projection...
KF-60XBR800
The first thing to check is for dry solder joints on all parts of the circuit board you are having problems with, but as for that popping sound more often than not it is caused by a faulty capacitor somewhere. Hope this helps.
Aug 22, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sound problem
  1. no picture &no sound raster ok.
  1. your problem is in tuner to vif section.
  2. check supply to TUNER & VIF section .
  3. check loose contact in above section.
  4. check components in VIF section.
  5. for ckt open the web site & download it fron there as given here.
  6. hope this will help.
  7. good luck.
http://www.eserviceinfo.com/index.php?what=search2
Oct 11, 2007 | Televison & Video
Televison & Video Logo
262 people viewed this question
Top Televison & Video Experts
