Question about Hitachi Saws
Just want to know the steps in changing a chop saw blade
  • 548 Answers
There should be a push in switch near the top back of the saw that pushes in and locks the blade, look for this blade lock and than you take the screw off that holds the blade in place and make sure you know the order of the washers and locks so you can replace the same way you took off
Posted on Sep 05, 2009
Can I use my metal chop saw to cut wood if I replace the blade with a wood saw blade?
Its conversely sometimes possible if you was asking about a wood saw with a steel saw blade but i cannot advice that in both application its not safe because not only of the difference of power but most it is the much higher RPM by diameter, just beware always on the max rpm you can read on your saw blades!!, it can give strange accidents with objects it can grab and swinging outbroken parts away.
Sep 28, 2016 | Makita "2414NB 14"" Chop Saw"
How do I change the saw blade in a Teledo TKZ 205 Chop saw
Using a set of vise grips clasp the blade so that the pliars get hung up on the blade housing/protector. Then get the correct size wrench and remove the nut and washer from the blade and replace it taking care to install it on the right side for proper cutting.
Sep 02, 2015 | Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
How do you remove the blade on my toledo chop saw
Unplug the saw first. Then raise the guard and lower the blade onto a piece of wood to keep the blade from turning. Using a proper wrench, turn the nut in the direction the blade spins when cutting and remove the nut and blade.
Sep 04, 2014 | Saws
How to change stihlsaw blade
Most petrol cut off saws have a 13mm bolt securing the blade.
Apr 01, 2013 | Milwaukee 6180-20 14" Chop Saw Abrasive...
Wires in switch
go to www.2helpu.com there you will get a wiring diagram for it.
Jan 15, 2013 | Dewalt "D28715 15 Amp 5.5 HP 14"" Heavy...
How to change the blade?
I don't know if this will help you much but I've got a DeWalt 14 inch chop saw and a 10 inch miter saw and they both have a small lever on the right hand side of frame just behind blade If you depress this lever and slowly rotate blade until it drops into place this locks the blade for changing. Hope this helps you. Thanks.
Nov 22, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
How do you change a quik change chop saw blade
Loosen shield screw so you can tilt it up far enough to get to the arbor bolt. Set the arbor lock on the saw and remove bolt.
Feb 20, 2010 | Dewalt Chop Saw D28700
How to keep the blade guard off the Circular saw blade when in use?
What is (B and Q) stand for ? This is a circular saw or a table saw, or a miter/chop saw?
Oct 11, 2008 | Saws
Saws Logo
97 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
