Question about Miele Dishwashers
Hello Intake /Drain light what does it mean and how do I fix the problem Thanks Steve Wheaton
  • steve417 Sep 10, 2009
    Hello
    Where is the filter?
    Steve
    President:
  • 1,714 Answers
This fault light is indicating that your not draining completely. The first solution recommended is to change the filter, and clean out machine bottom. (De-lime)
Posted on Sep 05, 2009
  • Craig Butler
    Craig Butler Sep 10, 2009
    For that specific model...I'm not sure, but it will be in the intake or the drain line. If you can pull off the front kick plate and take a look inside, you may be able to see it. It's just going to look like a filter unit. Some type of canister unit in the main hose lines.
Hi, My Miele G 2140 dishwasher bought five years ago just stopped working. It works until the Intake/Drain step of its cycle, then stops midway completely and the Intake/Drain light flashes. There is water...
Hello well you sure have the top of the line unit. You will have to pull it out and turn it over and remove the water pump and check for blockage the impeller should move when you turn it with your finger if not then replace the pump.
Sep 26, 2011 | Dishwashers
The starter clutch is slipping
Looking at the dragstar 100 maunal, there doesn't appear to be a starter clutch.
Maybe you mean the pre engage starter dog is not engaging. The manual just tell one to replace the motor. I would remove the starter, clean and lubricate the dog and bearing then put it back in as that usually fixes it.
Jan 20, 2011 | 2000 Yamaha V Star 1100 Custom
My intake/drain light is on. I have run my garberator. What else should I do to try and fix the problem?
A flashing "Intake/Drain," means something is wrong. It doesn't necessarly mean, "no water coming in," or "poor drainage." But of course, we should check those things first. What are the symptons? What part of the program does the "Intake/Drain" flash?
Oct 28, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Hello, I have a 2006 Volkswagen Convertible Beetle, and my check engine light is on. I got it checked and this is what they said: Code P0101 Mass or Volume Air Flow, Circuit Range/Performance. What does...
It means that the engine control unit (ecu) has recorded a reading outside the required parameters from the air intake sensor. Get the code cleared and check for air leaks around the air filter and intake pipes. Its likely to be an air leak rather than a defective sensor
Aug 11, 2010 | Volkswagen Beetle Cars & Trucks
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Miele intake light on since new sink,disposal installed
check and see if the disposer drain port plug was removed. intake/drain light means slow drain or no drain
Feb 04, 2009 | Miele Touchtronic G892 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Help with how to use properly a dishwahser.
You either have a blocked drain or pump or check to see if the water tap is turned on. It means that either the water wont pump out or fill with water. Good luck
Sep 27, 2007 | Miele Advanta G2020 Dishwasher
Dishwashers Logo
20 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
