Question about Bosch Axxis WFL 2060 Front Load Washer
Error message: water tap closed .
Machine displays error message that water tap is closed. have checked taps and water is there. unplugged machine for a few minutes to see if some chip needed rebooting. machine is 6 months old
  • Anonymous Mar 21, 2014
    washing machine works except the rinse cycle fails
  • 105 Answers
Check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
Posted on Jan 02, 2008
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Why is my machine not spinning
Well, it would help to know the make and model... on a Samsung the E8 code means the water hoses are connected to the wrong taps (i.e. the hot hose is hooked to the cold tap and vice-versa).
If it's not a Samsung, please provide more info.
Mar 08, 2015 | Washing Machines
My siemens IQ washing machine model 1434 says "Tap Closed" on the digital display and wont work. My spare washing machine works so there is nothing wrong with the taps in the plumbing. Is this a com
the water intake solenoid valve has failed
or the control board is not able to open it
i would check there it voltage at the solenoid 2 pins {mains here 120 or 240 v}
this opens the water in
if you have no voltage at the valve
then the controller board has an issue
or the door isnt detected as closed
some machines do a self test so
is there an actual error code
tap closed is no inlet
all valves have a small filter on the inlet side
use a pair a flat nose plyers too pull the filter cone out
and give it a clean
other than this the valve has failed or is seized
Aug 30, 2014 | Siemens Washing Machines
My Jura Capresso E 8 is stuck in open tap filling system. I open tap it says filling system, it says close tap, when I close the tap it goes back into open tap. Float valve looks fine, water is moving
Open the tap with frother spout off. This happened to mine and I took the frother tip off and opened tap with tip off. Water filled and I closed tap...Machine returned "Ready". I heated water in microwave for three minutes- placed frother tip in hot water and all kinds of gunk came out. Lesson learned- Do a thorough cleaning of frother by immersing it in very hot water at least once monthly- even if you don't use it
Jan 06, 2013 | Jura Capresso Impressa E8 Espresso/Coffee...
Washing machine not functioning...the service engineering has come and claims that the digital switch board is short circuited and gone and replacement would cost 2700/-Rs.....The machine stopped in...
Hi Nandita from retired Englishman in SW France,
This is a VERY difficult situation for us at FixYa to REMOTELY diagnose your symptoms. The service engineer is actually there looking at, and testing, the machine!
I will explain what the 4E and DE normally indicate and what normally to do about them ;-0)
4E Water supply error. (should clear pressing star/pause button if everything is OK)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
'DE' stands for Door Error.(should clear once the door is closed properly)
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 25, 2011 | Samsung Washing Machines
What does error f27 mean? During the wash cycle the water runs in the machine continuously and the displays "F27." The only way to shut off the water is to turn off the water tap. Even when the machine...
"F27" is an Overflow Condition error. The following link explains how to troubleshoot:
This can be one of the more difficult error codes to diagnose because there are so many potential causes. Read through the information provided and try to eliminate the easy (and obvious) things first. If you have any questions, please let me know. I hope this help you.
HINT: One obvious symptom that helps narrow down a potential cause is the fact that the washer does not stop filling with water even when unplugged. More than likely, you have a defective water inlet valve that is causing this.
Feb 06, 2010 | Kenmore Elite 45986 Front Load Washer
Error messages on my Ariston AVXD109
The washing machine fails to load water (The wording H20 is
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Sep 07, 2008 | Ariston Technologies AWD121WH
Bosch Axxis WFL 2060 Front Load Washer Logo
1,427 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
