Question about Ashton Digital Passport 2000 Notebook
Screen do not turn on..flicker then blank..not even to bios ..work last night...???????????? anybody know why.??very odd...
  • Stephan Reichert
    Stephan Reichert May 11, 2010
    Hello Firstly , what type of setup do you have? Are you using a PC or a Laptop? Is there a beep code , and if so...what make and model laptop/motherboard do you own and what is the combination of beeps (beep count and long/short). If not , the problem is most probably either a power supply or a blown motherboard or CPU. If you use a PC and the warranty is not voided by removing the cover ,remove the AC and open the side panel and physically check if all connections are firm by applying pressure. Plug in the AC power supply and switch on your PC. Note if all the fans in the system is running and note any unknown noises you do not recognize. Send me a reply to these questions and I will be better able to assist you.
    Sergeant:
    Champion:
  • 277 Answers
Insky_356,
Is this a notebook and who makes it?
If this is a notebook, you might have burnt out your LCD inverter. It is located under your keyboard.
Hope this helpful
Posted on Sep 05, 2009
Please can someone help me, I have an acer, model aspire 5535 laptop, Vista home basic OS installed, with a serious fault of not booting up. The night before it went dead it was working fine all evening...
Have you tried a different HD. If the vista download was the last thing you did, i would have thought that was your problem.
BUT i cant see that this would stop it from detecting the hard drive.
I had a similar problem on a desktop with a vista update, it had turned off my main hard drive as a bootable device in the bios, I dont know if you can get into the bios, but it may be worth taking a look
Sep 05, 2010 | Acer Aspire 5535-5050 Notebook
HP ML150 g5 dont star
1. try replacing thermal sensor
2. try replacing power supply
3. then systemboard last
Sep 24, 2009 | HP Compaq ProLiant ML110 G4 Server
ACER 6920G COMPLETELY BLANK SCREEN BUT LIGHTS COME ON + HDD
Ihate to be the bearer of bad tidings but the Motherboard CPU has gone to rest, and you should look into another laptop.
Jun 27, 2009 | Acer Aspire 6920 Notebook PC
HP ML150, blank display
Sounds like a system board or processor failure.
Apr 08, 2009 | HP Compaq ProLiant ML110 G4 Server
Blank Screen on HP Laptop
HP has identified a issue with the DV6000Z and monitor. I just reported the same problem to HP and even though off warranty, they will fix free. Power up of DV6000Z you will get 3 beeps and no monitor display. External monitor does not work either. This is a known issue woth the DV6000Z.
May 06, 2008 | HP Pavilion dv6000z Notebook
Screen seems to dim and there is flickering while watching
This is both a common and fairly easy repair in this unit. Remove the back, but not all of the back needs to be removed to access the power supply area and locate the power supply board. You might find that all three E919,E920,E921 of the 35v/680uf caps in the upper left of the PS board are bowed and/or vented. Replace all three of them even if they test good...
Next, esr the remaining caps. Last one we did here in the shop there were 16 total that we replaced, many were orange in color but I don't have any notes on their value. The orange color of the cap is a lesser temp range we used 105 degree or better as replacements. Some we used a higher rated cap (higher voltage) same uf rating. Gave it a greater reliability.
Good Luck!
Bill
Apr 08, 2008 | Insignia IS-LCDTV32 32 in. Television
Compaq presario v2000 monitor is having horizontal purple lines that flicker.
Try reloading the drivers, delete the device in device manager and reboot. It should then pick up the drivers and reload them, if that does not work I would suspect the screen is on its way out (flickering normally means the screen or its connection is bad)
Jan 26, 2008 | HP Compaq Presario V2000 Notebook
Screen on Toshiba M35x S149 Laptop blank/flickers
Ok, from the beginning. Can you do a cold boot and get into the bios? (is there an image on the screen then)
Secondly, can you connect to an external monitor and see an image?
Did it do this only when it was heading in to hibernation? If so, it sounds like the power management needs some adjustment.
If there's no image on the external monitor, you may have a video/motherboard problem, or it still could be the operating system/power management.
It all depends on if you have video in bios.
Let me know.
Good luck
Nov 10, 2007 | Toshiba Satellite M35X-S349 Notebook
Ashton Digital Passport 2000 Notebook Logo
48 people viewed this question
Top Ashton Digital Computers & Internet Experts
David Payne
David Payne
Masood Rasool
Level 1 Expert
Are you an Ashton Digital Computer and Internet Expert? Answer questions, earn points and help others
