Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Need new starter for cub cadet 1641 vanguard engine. How do you get the 13mm bolt out of the top of the starter mounting bracket with out taking the hole tractor apart? The bottom one is easy to get with a socket and extension bar.
  • 162 Answers
You should be able to find it here >>> http://www.partstree.com/parts/
Posted on Sep 09, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Extension with the swivel (wobble) end built into it...FYI, it is not a 13mm bolt.
Posted on Jun 17, 2013
How do I remove starter from 14 H.P. B&S vertical shaft engine?
Normally it hooks up to the engine at the top side where the flywheel is located..at the top you will find two small bolts..and at the bottom one or two wires..just disconnect the battery cables so no sparks or shorts when removing from the starter..then disconnect the starter wires set aside and then remove the two bolts..it should drop right out...note.. In some cases you may need to remove the engine shroud on the top to get at the bolts...not a hard job..if more the one wire...mark them or draw a diagram as where they were attached..good luck
Oct 21, 2014 | Rareelectrical STARTER MOTOR BRIGGS...
Belt routing for cub cadet 1641
Easiest way is to remember; flat side of belt goes onto flat pulleys and small V shape goes into V shaped pulleys.
Oct 08, 2014 | Garden
How do I remove the starter from a Kohler Courage 20hp vertical engine?
go to Partstree.com and look up the engine model.
You will get a nice breakdown.
I believe it is held on by 2 screws towards the top.
You should not have to remove the engine, just the upper housing.
Oct 07, 2014 | Garden
Cub cadet trouble shooting
bad rings need to rebiuld motor
Jul 04, 2014 | Garden
Starter motor hds 2165 cub cadet
One post, take a cheap thin wrench. Heat it, bent 90 d to fit in the space.
Apr 03, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Cub cadet 1641 how to remove starter motor
The top bolt is very difficult to reach. I ended up bending a 1/2" combination wrench to a right angle as close to the box end as I could. It was tedious to use, but it worked.
Jan 09, 2014 | Cub Cadet Garden
Cub cadet 1641 lt
starter gear is ground off you will have to replace it and hopefully not new starter
Nov 10, 2013 | Garden
Starter wont engage on 1641 lt cub
sometimes the shaft that the gear rides on gets dusty dirty and the Bendix gear cannot slide up. Is that what you have? You can hear it spin but doesn't engage the engine? A week battery will do that too. Thees CC starters like their voltage high
Nov 10, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
May 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
369 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
