Question about Motorola Mobility HS850 Consumer Headset
I could hold the button down all day long and the light will not stay on. Just blinks. Once I press it, it will blink forever! It literally blinked until 4am this morning! Thinking of throwing it against the wall.
  • dwbear37 Sep 08, 2009
    The boom is closed when I press the button but it never turns solid blue. Just blinks forever. I've tried many times and have given up.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 52 Answers
close the boom to keep it off. hold the button, open the boom (mic) right when it turns to solid blue, done!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
Posted on Sep 08, 2009
Try this hold down the button and the volume button at the same time
Posted on Sep 15, 2009
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
I need the insignia remote control code.
there are several and here they are 1181,1180,1175,1171,0103,0189,0217,0135,0133,0116,0167,1148,0456,0029,0905,1406,1407,1408
try each one seperate
press and hold the setup button until the red light stays on then if it is a universal remote press the desired mode button (example t.v.) the light should now blink and then stay on enter a 4digit code .
note:if the code is valid the light will turn off if the code is invalid then the light will flash.
now try it with your device on by pressing the channel up and down button.
note: if the remote does not control all the functions try another code.
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 29, 2009 | Insignia 42" LCD Flat-Panel HDTV
Remote code for sanyo tv
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES: 0049,0097,0110,0004,0268,0012,0108,0180
Aug 29, 2009 | Sanyo DS20930 20" TV
I have a Radioshack remote 15-2200 and I'm trying to program it to a JVC D-series TV please help
Codes: 0060,0026,0197,0069,0160,0247,0923,0012,0065,0067,0141
Aug 29, 2009 | Radio Shack 15-2200 Remote Control
Im trying t0 program a Phillips TV with a RCA niteglo universal remote.
Codes:
0154,1174,0062,0204,0004,0184,0208,0205,0206,0207,0189,0183,0199,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0140
Aug 29, 2009 | RCA Universal Remote 3 Device Remote...
I NEED THE CODE FO JVC
CODES: 0060,0026,0197,0069,0160,0247,0923,0012,0065,0067,0141
Aug 28, 2009 | One For All URC-4021 Remote Control
Sentry RMC-10 remote can't 'discover' my tv's code
.there are several codes. try each one seperate.
CODES:1171,0116,0167,0176,0922
Aug 28, 2009 | Sentry SE-RMC10 Remote Control
Programming my hitachi remote
CODES: 0545,0529,1754,0509,0465,0513,0518,0530,0531,0464,0511,0533,0526,0463
Aug 28, 2009 | Televison & Video
Need codes for rca remot control have phillps tv
CODES: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0199,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
Aug 28, 2009 | RCA Universal Remote Control
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
Motorola Mobility HS850 Consumer Headset Logo
133 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
