Question about Gateway Solo 5300 Notebook
Gateway 5350 solo laptop
I am trying to remove the case from the 5350. I believe that the dc power connector has gone bad, (it wiggles when you plug the ac cord in). I can get all but one corner loose. What am i missing?
  • denverd Nov 15, 2008
    I can't get the case open. It appears stck at one corner. I do not have a manual. Can you help????
IF YOU LOOK AT THE TUITORIAL ON THIS LAPTOP YOU WILL SEE THAT THE MONITOR SCREWS HAVE TO BE REMOVED AND THERE IS A SCREW UNDER IT THE TUITORIAL THAT YOU HAVE ON DISC OR DOWNLOADED WITH THE MACHINE WILL SHOW YOU EXACTLY WHERE IT IS AND HOW TO REMOVE IT
Posted on Dec 21, 2007
Power laptop fujitsu st4110
Could be a bad battery, a/c adapter or DC jack on the laptop.
Remove the battery and plug in the A/C and try to power on. If it comes on try to gently wiggle the plug where it meets the laptop. If it stays on then it's most likely a bad battery. If it shuts off when you wiggle it then the dc jack is bad. If none of these. Try gently wiggling the plug and tapping the power. If you get nothing at all it's probably the a/c adapter. If it comes on briefly then it's the dc jack
Jul 05, 2013 | Computers & Internet
Gateway MS2291 wont power up
Did you check the DC Jack where the Power Cord plugs into the laptop? If it is bad (wiggly or loose) then the laptop will not power on. Take an ink pen and put it where the power cord would plug into the laptop and see if the jack wiggles or is broken. If so, that's your problem.
The old power cord might be some good if the problem is with the DC Power Jack.
May 01, 2012 | Gateway Computers & Internet
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
No connection with the DC Jack on Gateway 3550GZ
It's time to take the computer to a qualified technician, for proper trouble-shooting & repair, because there are very-few "user-repairable" parts inside a laptop/notebook computer.
Jan 20, 2010 | Gateway 3550GZ Notebook
Replace DC power plug on Gateway CX210X laptop
Ok I just did this on my Gateway it is a different model though. I am not sure where you are stuck so I will start from the beginning. Remove all the screws from the back, then remove all the components (hard drive, cd rom, network card, battery etc.) beneath these components are more screws remove them. I do not know if you have removed your keyboard if not there are screws attatching it to the motherboard on the bottom remove those mine had three in various places like by the network card and dvd rom. If you are unsure consuly gateways website there are instructions for removing your keyboard. Beneath the keyboard there are more screws you will need to remove the monitor adapter in the rear unplug it from the motherboard and beneath it there are more screws. When you think you have removed them all gently pull on the motherboard from every side if it moves freely on eachside you are ready to dislodge it from the casing. If there is a location that is still firmly in place inspect that area from the top and bottom you should be able to locate the remaining screw.
The mother board does not slip out once all screw are removed it is lodged firmly in the case especially by the fan vent you have to coax it out.
Dec 12, 2009 | Gateway CX210X Notebook
Gateway Solo 9550 will not power on at all.
first you would try the least expensive
make sure your ac adpater works
the plug could be bad on the end
next is the pin inside the dc jack where you plug it in, if the pin moves just a little , you may need a new dc jack sold on ebay cheap
make sure the battery is out when testing
Dec 12, 2008 | Gateway Solo 9550 Notebook
Power Cord Slot Repair for a Gateway ML6230
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Nov 18, 2008 | Gateway ML6230 Notebook
Gateway M3A laptop DC power connector problem
You have 2 choices.. One : You can Desolder the DC Power Jack from the mainboard, clean the pins and connections on the board, then Resolder the DC Power jack back on. Or TWO: purchase a new DC Power Jack and Remove old one / replace with new one.. This will fix your Laptop Power problem..
Jun 02, 2008 | Computers & Internet
Computers & Internet Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
