Question about IBM ThinkCentre A51 PC Desktop
IBM ThinkCentre A51 PC Desktop won't boot motherboard power supply is good fan comes on. hard drive is spinning no video no audio or beeps
    Novelist:
  • 142 Answers
This could still possibly be a bad power supply, even if the fans and drives spin up. If you have a spare try hooking it up.
the list of things that can cause this are:
bad power supply
bad ram
IDE error (optical or hard drive problem)
bad card (modem, video card etc.)
bad processor
bad board
The first thing i would look for in this case is blown capacitors. Those are the little things on the board that look like little soup cans, usually with silver tops. If the tops of any of them are bulging or have junk leaking out of them, you have a bad board. If you are handy with a soldering iron you can try to replace them. Not sure if radio shack still sells caps, but they are easy to find on line. I have about an %80 success rate fixing boards in this way.
If the PS change doesn't work, then try it with different sticks of RAM, if you have more than one, pulling one at a time until it starts or you've tried it with all the ram. If not ram, disconnect the ide cables from the board, these are the wide ones usually connected to the HD's and optical drives. If it still doesnt start then pull all the cards. If it doesnt start then, try swapping processor and if still no joy a new board.
Posted on Sep 05, 2009
When i start the system the fan runs in high speed and the system is not booting atall <!-- from fixya rte -->
Posted on Aug 16, 2010
  • Michael Snyder
    Michael Snyder Jun 01, 2011
    Can you get into the BIOS Setup Utility?
    Scholar:
  • 92 Answers
Try getting into the BIOS Setup Utility and load all defaults.
To start the Setup Utility program, do the following:
1. If your computer is already on when you start this procedure, shut down the operating system and turn off the computer.
2. Press and hold the F1 key then turn on the computer. When you hear multiple beeps, release the F1 key.
Notes:
a. If you have a USB keyboard installed on your computer and the Setup Utility does not display using this method, turn on the computer, then immediately press and release the F1 key repeatedly until the Setup Utility displays.
b. If a user password or an administrator password has been set, the Setup Utility program menu is not displayed until you type your password.
I hope this helps.
Mike
Posted on Jun 01, 2011
When i start the system the fan runs in high speed and the system not booting, i have tried with replacing RAM, SMPS still then the problem persist
The fan you hear when the the computer start, is the power supply fan, the system not booting up mean you should check the cable which connect the monitor to the computer If the connection it proper then you should check the video card you can do this by try using another monitor or replace the video card because if its faulty the computer will never boot.
Aug 16, 2010 | IBM ThinkCentre A51 PC Desktop
IBM ThinkCentre S51 Intel Pentium 4 PC Desktop won't boot up. The power light comes on for about a second and then goes off, over and over again. It does not stop unless I unplug it. The mouse's infrared...
Sounds like it's probably the power supply. The computer takes more power to boot up than to run, so if it can't get enough wattage it can't boot all the way up, and it will shut down and try again.
If you're comfortable opening your computer up, you can test the power supply connectors with a voltmeter or multimeter to verify. A new power supply is typically only $30 or $40.
May 29, 2010 | IBM ThinkCentre A51 PC Desktop
My ibm think centre wont boot i hear the fans come on but no boot
Hello
Without a laptop model number, we can only give you general advice.
Does the laptop beep when you turn it on? If it does, the number of beeps will indicate what is wrong.
If it does not beep, there may be a power issue - try removing the battery and use the AC Adapter only. Also, try swapping out the power adapter if you can.
Here is a link lor Lenovo (they bought IBM laptop and desktop) general troubleshooting page...
http://www-307.ibm.com/pc/support/site.wss/MIGR-4XVQAL.html
Apr 30, 2010 | IBM ThinkCentre A51 PC Desktop
IBM Think Center A51, 8131-35U will not boot up. Fan comes on but nothing else. Power Supply checks out good. If it is a mother board problem, is it fixable? I tried another hard drive and I do get a...
IF your systems turns on no beeps ...everything seems to work just no display on the screen then i guess would should try discharging your system - ie un plug the power cord take out the Motherboard ,ram , basically take everything apart leave it for a day and connect everything back again ti should work
Sep 05, 2009 | IBM Computers & Internet
Lenovo thinkcentre a51 reboots with several beeps
There is a system error in the system. Would be hard to determine cause of the error without viewing an error log. I recommend, using system restore and setting the pc back to a time it worked good. Otherwise, download a free registry error cleaner and registry optimizer called "glary utilities" from glaryutilities.org
Run the program to get all the bugs out of your pc
Aug 04, 2009 | IBM ThinkCentre A51 PC Desktop
IBM Thinkcentre A51
please check the system board if there is any bloated capacitor,and also try to take out the cmos battery reset the cmos and try to boot,if it fails,its system board.replacement needed
Nov 21, 2008 | IBM ThinkCentre A51 PC Desktop
IBM THINKCENTRE A51 - WON'T BOOT
Simple dear, I think that you can see the power led and hdd led but it wont boot. Right. So switch the system and than open the cabinet and than remove the RAM , CLEAR THE DUST ON THE SLOT AND RAM. THAN REPLUG IT IN THE SAME WAY. PLEASE DO NOT INSERT IT FORCEFULLY BECAUSE IT WILL GO EASILY IF YOU ARE INSERTING IT IN RIGHT WAY. SO CHECK THE POSITON OF THE NOTCH ON BOTH THE RAM AND SLOT OK
AND THAN START THE SYSTEM. THIS MIGHT DEFINATELY SOLVE YOUR PROBLEM.
Nov 19, 2008 | IBM ThinkCentre A51 PC Desktop
IBM ThinkCentre A51 PC Desktop Logo
1,653 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
