Question about Weber Genesis Silver B Grill
My weber grill is not heating up high enough.
My grill will not heat up past 250. I have a full tank. help....
cdenham1st
  • 3 Answers
SOURCE: my weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Posted on Mar 21, 2009
frcs68
  • 1605 Answers
SOURCE: weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Posted on Mar 24, 2009
  • 3 Answers
SOURCE: Weber Silver B - 3 burner BBQ
Check your instruction manual, you have probably set off the safety valve in your propane tank. It is set to trigger if there is an open connection, such as turning on the jets when the tank is turned off. You may have to re-connect the tank...careful of course, make sure it's valve is off.
Posted on Aug 24, 2008
  • 60 Answers
SOURCE: weber grill wont heat past 350 degrees. Tank is
either your regulator is not hooked up to the tank all the way try to turn tank off make sure all knobs are turned off disconnect tank then reconnect turn tank on and try again if this doesnt work the regulator is bad
Posted on Aug 09, 2009
  • 332 Answers
SOURCE: The heat on m Weber grill would not go above 250
The new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Posted on Mar 29, 2010
We have a Weber Genesis Grill Silver and now we thought we needed gas and got a new tank. Okay now it will not heat up past 250 degrees. We found out about the trick with turning on the gas and...
Well, if turning OFF the tank valve, disconnecting the hose and wait 5 minutes before reconnecting it. And then, opening the tank valve VERY, VERY, SLOWLY (Slow motion slow) before lighting the burner farthest from the tank first and turning it to high didn't work. You need to replace the grill's hose/regulator assembly.
You can purchase one at any home center or hardware store that sells gas grills and accessories. They run around $30.00. Be sure to take your old one with you for comparison purposes.
Hope this helped you and Happy Grilling!!
Jun 06, 2011 | Weber Genesis Silver B Grill
No matter how long I let it heat up never goes past 250 degrees
First, do the flames on the burners, when they're on high, appear to be normal? Or are they lower than normal, despite the burner knob(s) being turned to high? Do you turn the tank OFF after grilling each time?
If you answered yes, to the last two questions, here's what you need to do. Turn the tank valve OFF. Disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Turn the tank valve ON VERY, VERY SLOWLY, until it's completely open. Light each burner individually and turn the burner knob to high. Once all the burners are lit and turned to high, do the flames look taller than before?
If so, you just solved your problem. Remember to turn the tank valve on VERY, VERY SLOWLY each time you turn it ON.
If the above is not the problem, the grill thermostat may be faulty. To test this theory, purchase an inexpensive Oven Thermometer and place it on the grill grates, when preheating your grill. Close the lid of the grill and ten minutes later, take a look at the Oven Thermometer and compare it's temperature with the grill thermometer. If the grill thermometer is reading significantly lower than the Oven thermometer, you need to replace the grill thermometer. You can purchase one directly form Weber.
Hope this helped you solve your problem. Happy Grilling!
Feb 20, 2011 | Weber Genesis Silver B Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Genesis Silver B Grill
When I turn on the gas to my grill, not enough gas comes through the inside of the grill to heat the grill. The tank is full, all of the grates are new. It will only heat to around 200 degrees
That would be a regulator problem, assuming that the gas tank ain't almost shot...
Get a new regulator and that will get you that burger...
heatman101
Aug 22, 2010 | Weber Grilling
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
Grill won't heat up
i would make sure the valve on the tank is open all the way counter clockwise
Apr 24, 2010 | Weber Genesis Silver A Grill
My q grill is not heating properly. I have a full tank of propane and the grill is clean but the burner is not getting enough gas to heat past 200 degrees
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Mar 30, 2010 | Weber Q Grill
Weber grill wont heat past 350 degrees. Tank is full. Not leaking gas.
Aug 09, 2009 | Weber Genesis Silver C Grill
Weber gas grill wont heat past 300 degrees
Mar 23, 2009 | Weber Genesis Silver C Grill
My weber gas grill will not heat up past 300F
Hi John,
Sloution;
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Weber Genesis Silver B Grill Logo
1,097 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
